Home » Newcomers » Newcomers » Web Application from Apache Buildr(Converting an imported projected into a Web Application)
Web Application from Apache Buildr [message #1115094] Mon, 23 September 2013 12:48 Go to next message
I have imported a project (a web application, though not recognised as such by Eclipse Juno, which recognizes it as a Java App).
The application was put together to run on JBoss 4.2.3 GA, using Apache Buildr to compile and war it up.
However, the only way I will be able to realistically work with this application (given the work I must do in the timeframe I have to do it in) is to be able to run it as a web application in Eclipse (to use the debugging tools, etc.).
What would be the best way for me to convert this thing over so that I do not use their apache build scripts to build their war file and deploy in jboss, rather, to compile and run in Jboss in eclipse as a web application.
Any ideas? Thanks. RVic
Re: Web Application from Apache Buildr [message #1115101 is a reply to message #1115094] Mon, 23 September 2013 13:03 Go to previous message
> application.
I'm interested in an answer to this too (as a "best practice"). You
might, however, find more and better help in the Eclipse web tools
platform forum.
Previous Topic:Eclipse keep's re-indexing and kills my computer? [MAC OS X]
Next Topic:how to generating pdf using birt?
Current Time: Mon Jul 28 13:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.30611 seconds
