Using DSL-Editor in an older Eclipse [message #1114946] |
Mon, 23 September 2013 08:54  |
I want to use my DSL-Editor in an every-day-Eclipse. For the same version of Eclipse I can follow the description on the internet-site:
http://wiki.eclipse.org/Xtext/GettingStarted#Deployment
This works fine, if I use the same version of Eclipse for developing the DSL and the exported an deployed DSL-Editor.
But we want to decouple the developing of the DSL and the use of the Editor. Currently we use Kepler to develop the DSL. However we want to use the Editor in Indigo.
If I use the description from the link above I get some reasonable errors of missing some libraries.
Is there a way to export all required plugins so I can use the DSL-Editor in an older-versioned Eclipse?
("Reexport this dependency" and installing Xtext does not fix my problem)
Eclipse- and Xtext-Version, which was used to develop the DSL:
Kepler Build ID: 20130614-0229, Xtext 2.4.3
Eclipse, which is used in every-day-work:
Indigo Build id: 20110916-0149
Greets Björn
[Updated on: Mon, 23 September 2013 09:00] by Moderator
Re: Using DSL-Editor in an older Eclipse [message #1114999 is a reply to message #1114946] |
Mon, 23 September 2013 10:10   |
On 23/09/2013 14:54, Björn Rellesch wrote:
> Hello,
> DSL-Editor in every older-versioned Eclipse?
> ("Reexport this dependency" does not fix my problem)
> Indogo Build id: 20110916-0149
> Greets Björn
If you use a target platform with Xtext 2.4.3 and Indigo Platform this
should work... are you using a target platform at all?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Using DSL-Editor in an older Eclipse [message #1115633 is a reply to message #1114946] |
Tue, 24 September 2013 07:08  |
You would have to build a feature project containing you DSL, and build a p2 repository that contains that feature. The appropriate way to achieve this is to build your plugins with a build framework (Maven Tycho or Buckminster).
From the resulting p2 repository you could install your DSL feature into your Indigo installation. All dependent plugins will be installed if the appropriate repositories (i.e. your DSL repository and Xtext repository) are available.
See the developer guide of project Spray for details on build setup. Maybe not the "easy" solution you would like to have, but the right one. The approach described in the Deployment guide of the Xtext manual only suites for the trivial case that the DSL feature is installed on a predefined Xtext enabled local Eclipse distribution. In production this is usually not what you want.
~Karsten
FUDForum. Page generated in 0.46236 seconds
