lowResourcesConnections attribut doesn't work with jetty8.1.11 [message #1114370] |
Sun, 22 September 2013 12:38  |
I have recently upgrade jetty from 7.0.1 to 8.1.11.v20130520.
For limiting number of connections, I have modified connectors value in the jetty.xml file. I have set the value of attributes "lowResourcesConnections" and "lowResourcesMaxIdleTime" to 1000 and 5000 respectively.
But, the no. of tcp connections goes above this limit(1000) and jetty unable to close the open idle connections. Number of connections reached to the 2^16(i.e. max. connections OS support).
In jetty 7.0.1, the attribute lowResourcesConnections work fine, and no. of connections never cross the limit set by this parameter. But after upgrading jetty, this parameter stop working.
Please let me know, if I missed something during jetty configuration or this is bug on jetty 8.1.11.
Priya
Re: lowResourcesConnections attribut doesn't work with jetty8.1.11 [message #1114969 is a reply to message #1114370] |
Mon, 23 September 2013 09:30  |
On 9/22/2013 6:20 PM, priya jain wrote:
> I have recently upgrade jetty from 7.0.1 to 8.1.11.v20130520. For
> respectively.
> Priya
This might be more appropriate in the Eclipse web tools platform forum.
FUDForum. Page generated in 0.08423 seconds
