Home » Modeling » TMF (Xtext) » Value Converters in Xtext(Value Converters in Xtext)
icon5.gif  Value Converters in Xtext [message #1114705] Mon, 23 September 2013 01:15 Go to next message
Hello all,
Can we use Value Convertes in xtext for the rules which are not terminal?
If yes then , Can someone let me know how do I do it ?
Thanks in advance Smile
Re: Value Converters in Xtext [message #1114711 is a reply to message #1114705] Mon, 23 September 2013 01:21 Go to previous messageGo to next message
I guess you are not talking about data type rules (which are actually
parsed)
For the rest: no.
Can you give some more hints on your usecase
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Value Converters in Xtext [message #1114718 is a reply to message #1114711] Mon, 23 September 2013 01:39 Go to previous messageGo to next message
Hi Christian,
Thanks for your reply Smile
Ok Let me explain you my use case,
I have a grammar something like:
SomeExpression:
SomeOtherExpr (rest part of the grammar);
SomeOtherExpr:
SomeAnotherExpr (rest part of the grammar);
SomeAnotherExpr:
INT | DOUBLE| LONG ;
For me , SomeExpression rule will return some value at the end which I am interested in.
So can I write the value converter for SomeExpression ?
Re: Value Converters in Xtext [message #1114723 is a reply to message #1114718] Mon, 23 September 2013 01:44 Go to previous messageGo to next message
hi,
the problem is; your snippet is incomplete, you dont use assignments, so i cannot say.
if you dont use assignment then rulecalls mean "is a" and thus inheritance
SomeOtherExpr:
value=SomeAnotherExpr (rest part of the grammar);
SomeAnotherExpr:
Re: Value Converters in Xtext [message #1114751 is a reply to message #1114723] Mon, 23 September 2013 02:42 Go to previous messageGo to next message
Hi Christian,
I missed one point.
In my grammar, I have the assignment like:
value=SomeExpression
And this SomeExpression has sub rules and assignments as written above.
I want to write a value Converter for this SomeExpression. I tried writing it. The method is getting called but I get string as null value in toValue(final String string, final INode node) method.
Any suggestions??
Re: Value Converters in Xtext [message #1114755 is a reply to message #1114751] Mon, 23 September 2013 02:46 Go to previous message
Please show all relevant parts of the grammar.
Strip it down to a simple example grammar.
Please note: do not use any assignments In datatye rules.BTW your
type is string (the grammar snippet indicates that)
Previous Topic:Two similar rules, but with different cross-references
Next Topic:URIImport of a non-xtext resource and referencing of its declared objects
Current Time: Fri Jul 25 23:10:10 EDT 2025
Powered by FUDForum. Page generated in 0.21276 seconds
