Home » Modeling » TMF (Xtext) » Two similar rules, but with different cross-references
Two similar rules, but with different cross-references [message #1114364] Sun, 22 September 2013 12:27 Go to next message
consider following grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	examples+=Example*;
Example:
	Object|Var|ObjectCall|VarAssignment
Object:
	'object' name=ID
Var:
	'var' name=ID
ObjectCall:
	object=[Object]'.'method=ID('('(arguments+=[Var](','arguments+=[Var])*)?')')?
VarAssignment:
	var=[Var]('.'attribute=ID)? '=' int=INT
The problem is, that the ProposalProvider and the Validator always assume that a VarAssignment is an ObjectCall until '=' is entered.
Now my question is, is there an elegant way to specify these rules, keep the benefit of cross-references and get correct proposals?
Thanks!
Re: Two similar rules, but with different cross-references [message #1114457 is a reply to message #1114364] Sun, 22 September 2013 15:29 Go to previous message
You could use backtracking; hardly elegant.
You could restructure your grammar so that the conflicting syntaxes are
unified and resolved later semantically.
You could change to an LALR technology.
Ed Willink
On 22/09/2013 17:27, Joe I wrote:
> Model:
> examples+=Example*;
> Example:
> Object:
> 'object' name=ID
> Var:
> 'var' name=ID
> ObjectCall:
> VarAssignment:
> Thanks!
Previous Topic:What's necessary for using uml2 within xtext plugin?
Next Topic:Value Converters in Xtext
Current Time: Wed Jul 23 05:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.05168 seconds
