Theming not applied on Text and Label Font [message #111433] |
Thu, 06 November 2008 09:18  |
Originally posted by: benjamin.wolff.web.de
using the latest and greatest vom CVS, it seems that the theme does not set the
Label and Text widget fonts correctly, they default to standard font. The same
theme properties file works as it should against RAP 1.1.1
was there a change in the theme properties file? the "widget.font:" attribute
doesn't seem to apply on Label and Text anymore, the theme.properties in the CVS
Demo Project doesn't show any new attributes.
Greetings,
-Ben
Re: Theming not applied on Text and Label Font [message #111518 is a reply to message #111433] |
Thu, 06 November 2008 12:58   |
Hello again,
i migrated to a CSS Theme File after reading the RWT Theming article here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.rap.help/help/html/advanced/theming.html
No the fonts are correctly set, again.
I can advice anyone else who also experiences problems with the .properties theme
to change to a CSS file, since the old .properties theming is deprecated anyway.
HTH,
-Ben
Ben W. schrieb:
> Hello,
> set the Label and Text widget fonts correctly, they default to standard
> font. The same theme properties file works as it should against RAP 1.1.1
> attribute doesn't seem to apply on Label and Text anymore, the
> theme.properties in the CVS Demo Project doesn't show any new attributes.
> Greetings,
> -Ben
Re: Theming not applied on Text and Label Font [message #111564 is a reply to message #111518] |
Thu, 06 November 2008 16:52  |
Originally posted by: rsternberg.innoopract.com
Hi Ben,
thanks for reporting this defect. It is fixed in CVS HEAD now.
Anyway you are right, CSS is the way to go. In fact, we plan to
discontinue the properties-theming support in the near future.
But this will be announced separately here.
Ralf
Ben W. wrote:
> Hello again,
> .properties theme to change to a CSS file, since the old .properties
> HTH,
> -Ben
> Ben W. schrieb:
>> Hello,
>> not set the Label and Text widget fonts correctly, they default to
>> standard font. The same theme properties file works as it should
>> against RAP 1.1.1
>> Greetings,
>> -Ben
FUDForum. Page generated in 0.29745 seconds
