Home » Newcomers » Newcomers » Eclipse crashes with exit code 1
icon5.gif  Eclipse crashes with exit code 1 [message #653614] Thu, 10 February 2011 07:21 Go to next message
I know this is a known problem and I have been looking in a lot of other forums for a way to fix this problem but never found one that works for me. So I thought I should as here but I'm not sure if it's the right place.
As mentioned in the title Eclipse crashes and does it a lot. It gives no warning, just shuts down and gives the following message:
Java was started but returned exit code=1
c:\windows\system32\javaw.exe
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar C:\eclipse\plugins/org.eclipse.equinox.launcher_1.10.v201005 07.jar
-os win32
-ws win32
-arch x86_64
-showsplash
-launcher c:\eclipse\eclipse.exe
-name Eclipse
--launcher.library
c:\eclipse\plugins/org.eclipse.equinox.launcher.win32.win32. x86_64_1.1.1.R36x_v20100810\eclipse_1309.dll
-startup c:\eclipse\plugins/org.eclipse.equinox.launcher_1.1.0.v20100 507.jar
-exitdata bf0_5c
-vm c:\program files\java\jdk1.6.0_23\bin\javaw.exe
-vm c:\windows\system32\javaw.exe
-vmargs
-Xms40m
-Xmx512m
-jar c:\eclipse\plugins/org.eclipse.equinox.launcher_1.1.0.v20100 507.jar
I am using Windows 7 64 bit, Java 1.6 Update 23 for windows 64 bit, and eclipse helios 3.6.1 for windows 64 bit.
This is my eclipse.ini file:
-startup
plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 1.R36x_v20100810
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-Xms40m
-Xmx512m
I have tried to add the: -vm c:\program files\java\jdk1.6.0_23\bin\javaw.exe
line which I read about in some forum. I have tried to re-import the workspace which I read could be a problem too.
Does anyone have any ideas of what I can do to solve this or at least point me in the right direction?
I appreciate any answer!
// André
Re: Eclipse crashes with exit code 1 [message #653641 is a reply to message #653614] Thu, 10 February 2011 09:08 Go to previous messageGo to next message
Sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=333227
HTH,
Toni
> -Xms40m
> -Xmx512m
> -os win32
> -ws win32
> -arch x86_64
> -showsplash
> -name Eclipse
> --launcher.library
> 507.jar
> -exitdata bf0_5c
> -vmargs
> -Xms40m
> -Xmx512m
> -startup
> --launcher.library
> 1.R36x_v20100810
> -showsplash
> 256m
> openFile
> -vm c:\program files\java\jdk1.6.0_23\bin\javaw.exe -vmargs
> -Xms40m
> -Xmx512m
> files\java\jdk1.6.0_23\bin\javaw.exe line which I read about in some
> problem too.
> // André
Re: Eclipse crashes with exit code 1 [message #653912 is a reply to message #653641] Fri, 11 February 2011 15:40 Go to previous messageGo to next message
That fixed it!
I added the line:
-XX:-UseCompressedOops
to eclipse.ini and so far so good! 24h without crashing. A new record!
icon14.gif  Re: Eclipse crashes with exit code 1 [message #665546 is a reply to message #653912] Fri, 15 April 2011 00:20 Go to previous messageGo to next message
Adding '-XX:-UseCompressedOops' to the eclipse.ini worked!
Thank you all.
This has been driving me crazy for days!
Re: Eclipse crashes with exit code 1 [message #665823 is a reply to message #653614] Sat, 16 April 2011 10:30 Go to previous messageGo to next message
This helped me too. I am a newbie setting up eclipse and C++ so it took me a couple of iterations as I was not sure where in the ini file I needed to add it and found it worked if it was the last line I had to add the command -XX:-UseCompressedOops
at the end of the eclipse.ini file:
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_14 00.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 2.R36x_v20101222
-showsplash
256m
openFile
-vm
C:\Program Files\Java\jdk1.6.0_24\bin\javaw.exe
-vmargs
-Xms40m
-Xmx192m
Re: Eclipse crashes with exit code 1 [message #973086 is a reply to message #653614] Mon, 05 November 2012 23:17 Go to previous messageGo to next message
On windows 7, use '-XX:+UseCompressedOops' instead '-XX:-UseCompressedOops'.
Re: Eclipse crashes with exit code 1 [message #999004 is a reply to message #973086] Fri, 11 January 2013 01:18 Go to previous messageGo to next message
I have tried above mentioned procedures, but I am still getting the same error.
Please do help
Re: Eclipse crashes with exit code 1 [message #999011 is a reply to message #653614] Fri, 11 January 2013 01:34 Go to previous messageGo to next message
Problem solved..:)Smile
Thank u..
Re: Eclipse crashes with exit code 1 [message #1001059 is a reply to message #999011] Tue, 15 January 2013 18:57 Go to previous messageGo to next message
How do u solve?
Re: Eclipse crashes with exit code 1 [message #1050249 is a reply to message #653614] Fri, 26 April 2013 19:12 Go to previous messageGo to next message
If you are running Windows 7 and the error is still occurring, try running the application as administrator.
Re: Eclipse crashes with exit code 1 [message #1060577 is a reply to message #665546] Mon, 27 May 2013 03:04 Go to previous messageGo to next message
I have this problem too.
Where sould I write this line?
(What is eclipse.ini?)
Thanks!
Re: Eclipse crashes with exit code 1 [message #1060579 is a reply to message #1050249] Mon, 27 May 2013 03:20 Go to previous messageGo to next message
I try both,
But it still crashed with same error.
What can I do?
Re: Eclipse crashes with exit code 1 [message #1079503 is a reply to message #653614] Sun, 04 August 2013 14:00 Go to previous messageGo to next message
Im running Win 7, 64bit
Ive tried the following:
    Adding -Xint to the ini file
    Adding --XX:-UseCompressedOops to the ini file
    Adding -XX:+UseCompressedOops to the ini file
    Running as Administrator
Nothing has worked.
Anyone have any other suggestions?
Re: Eclipse crashes with exit code 1 [message #1114010 is a reply to message #1079503] Sat, 21 September 2013 23:29 Go to previous messageGo to next message
Try with java.exe instead of javaw.exe, worked for me
---vm
---<yourjavainstallation>/bin/javaw.exe
-vm "<yourjavainstallation>\bin\java.exe" -consoleLog -debug
Re: Eclipse crashes with exit code 1 [message #1818472 is a reply to message #653614] Mon, 16 December 2019 21:12 Go to previous messageGo to next message
it has worked for me (note:-adding at the bottom only)
Re: Eclipse crashes with exit code 1 [message #1851280 is a reply to message #1818472] Fri, 01 April 2022 06:50 Go to previous messageGo to next message
I have tried all possible procedure above ,but none works.
As a comparision, I do the same building with the same eclipse and the same java on windows 10 , this error doesnot shows up anymore.
but for some reasons, we can not turn the server from windows 7 to windows 10, we do not know how to fix it.
Re: Eclipse crashes with exit code 1 [message #1851292 is a reply to message #1851280] Fri, 01 April 2022 10:41 Go to previous message
I'm a bit doubtful that your problem is the same as above. Best would be if you provide specific details. E.g., which version of Java are you using? In which absolute path is Java installed? What's in your eclipse.ini, i.e., do you specify a -vm option in that file? Did you try installing using the installer, which tests the JDK/JREs on your system to choose an appropriate/correct one and record it in the -vm option of the eclipse.ini...
Previous Topic:software minimalism & xdebug port messup & firefox-style hotkeys?
Next Topic:eclipse - java
Current Time: Sun Nov 02 21:00:29 EST 2025
Powered by FUDForum. Page generated in 1.28293 seconds
