Load user image at runtime [message #1112319] |
Thu, 19 September 2013 08:30  |
I have a Graphiti diagram representing scientific functions as rectangle. Each function has a Latex documentation. The user can change the documentation with a dialog box. When the dialog is closed, a "png" image is generated from the Latex entry. Is it possible to display this image into the rectangle representing the function ?
I try to use the ImageProvider but images have to be packaged with the plugin and the ImageProvider looks for images only in the plugin path. In my case, images are generated at runtime, during the use of my graphiti editor. I can build an swt image but not a Graphiti one. Any Idea ?
Thanks for your help.
Re: Load user image at runtime [message #1735405 is a reply to message #1138669] |
Sat, 18 June 2016 10:19  |
I'm trying to achieve the same thing but i'm not getting it to work, even with the solution Felix Velasco proposed.
I've added the following method to my subclass that extends AbstractImageProvider:
public void addImage(String imageId, String imageFilePath){
super.addImageFilePath(imageId, imageFilePath);
I use the following code to get the Image from the runtime project and to make it available for the ImageProvider:
IResource res = ResourcesPlugin.getWorkspace().getRoot().findMember("/test/src/channelTypes/sync/images/decorator-target.png");
imageProvider.addImage("reo.editor.test", res.getLocationURI().toString());
The ResourcesPlugin does seem to find the image, but unfortunately, i'm getting the following error when I start the project.
at org.eclipse.jface.resource.ImageDataImageDescriptor.hashCode(ImageDataImageDescriptor.java:84)
at java.util.HashMap.hash(Unknown Source)
at java.util.HashMap.get(Unknown Source)
at org.eclipse.jface.resource.AbstractResourceManager.create(AbstractResourceManager.java:77)
at org.eclipse.jface.resource.ResourceManager.createImageWithDefault(ResourceManager.java:192)
at org.eclipse.jface.resource.ImageRegistry.get(ImageRegistry.java:214)
at org.eclipse.graphiti.ui.internal.services.impl.ImageService.getImageForId(ImageService.java:80)
at org.eclipse.graphiti.ui.internal.parts.PictogramElementDelegate.refreshFigureForGraphicsAlgorithm(PictogramElementDelegate.java:599)
at org.eclipse.graphiti.ui.internal.parts.PictogramElementDelegate.refreshFigureForPictogramElement(PictogramElementDelegate.java:1275)
at org.eclipse.graphiti.ui.internal.parts.PictogramElementDelegate.refreshFigureForEditPart(PictogramElementDelegate.java:357)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.refreshVisuals(ShapeEditPart.java:704)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:725)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.refresh(ShapeEditPart.java:596)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.refreshChildren(ShapeEditPart.java:682)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at org.eclipse.graphiti.ui.internal.parts.DiagramEditPart.refresh(DiagramEditPart.java:189)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.graphiti.ui.editor.DiagramBehavior.initializeGraphicalViewer(DiagramBehavior.java:605)
at org.eclipse.graphiti.ui.editor.DiagramEditor.initializeGraphicalViewer(DiagramEditor.java:348)
at org.eclipse.graphiti.ui.editor.DiagramBehavior.createGraphicalViewer(DiagramBehavior.java:496)
at org.eclipse.graphiti.ui.editor.DiagramEditor.createGraphicalViewer(DiagramEditor.java:335)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette.createPartControl(GraphicalEditorWithFlyoutPalette.java:74)
at org.eclipse.graphiti.ui.editor.DiagramEditor.createPartControl(DiagramEditor.java:320)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:151)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:341)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1306)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:658)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:654)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:525)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:509)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:69)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:151)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:63)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:614)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1061)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Maybe this is related to:
https://www.eclipse.org/forums/index.php/t/1067880/ ?
Anyone knows a solution?
[Updated on: Sat, 18 June 2016 10:21] by Moderator
FUDForum. Page generated in 0.21101 seconds
