Home » Eclipse Projects » Gemini » ATTN: Gemini Management subproject about to be shut down!
ATTN: Gemini Management subproject about to be shut down! [message #1078107] Fri, 02 August 2013 10:47 Go to next message
The subject of this topic describes the most likely outcome now that the subproject lead has moved on. Since nobody has stepped in to volunteer to lead the Gemini Management subproject it will be terminated/sit in hibernation, with no development, maintenance or support.
If you use Gemini Management and/or are interested in becoming the lead please make it known ASAP either by replying to this post or by emailing the common Gemini dev mailing list (gemini-dev@eclipse.org). No experience is necessary, but either a knowledge of, or willingness to learn about the project is obviously going to help! The time commitment depends upon the volunteer, but a couple of hours a week is an estimated minimum.
Thank you.
-Mike Keith
Gemini parent project lead
PS Note that Gemini DBAccess, Gemini JPA, Gemini Web and Gemini Naming are still very much active projects with project leads and committers.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1084988 is a reply to message #1078107] Mon, 12 August 2013 05:45 Go to previous messageGo to next message
To anyone thinking about stepping up, the time required is even less than Mike has suggested. The project simply provides an implementation of the OSGi enterprise JMX spec. There should be no major work required unless the spec changes or you feel like improving the test coverage. The code base isn't very big and no bugs have been raised in quite some time. I'm not disappearing off the internet and I'm more than happy to provide any help wanted to someone stepping up.
Thanks, Chris.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1111809 is a reply to message #1084988] Wed, 18 September 2013 15:19 Go to previous messageGo to next message
As Management, Virgo is without a project leader too, and on risky to be shutdown too!
http://www.eclipse.org/forums/index.php/t/526871/
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112197 is a reply to message #1111809] Thu, 19 September 2013 04:38 Go to previous messageGo to next message
Fear not, Florian Waibel from Eclispe source has stepped up to take on the leadership of Gemini Management. The paperwork is in progress at the moment. We are still looking for someone to take on Virgo, if you or your company are using Virgo why not see if a little extra commitment to the project would be acceptable and step up to take the lead.
Chris.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112420 is a reply to message #1112197] Thu, 19 September 2013 13:14 Go to previous messageGo to next message
Hi Chris Frost! Good news!!
Unfortunatelly, about Virgo, I'm not work on any company right now. I'm trying to open one, and I'm developing a new product to do that, and I have a contract with a small company of some friends, to fit my basic needs in this time.
To make things harder, I'm just an user of Virgo. I'm not a OSGi specialist, and I dont know Virgo internals. My knowledge is very far from any Virgo commiters Sad.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112843 is a reply to message #1112420] Fri, 20 September 2013 04:48 Go to previous messageGo to next message
Your startup is based on top of Virgo, awesome, I'm intrigued. Tell us more!
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112931 is a reply to message #1112843] Fri, 20 September 2013 07:33 Go to previous message
Hi Chris!
I'm working on a project of a production automation system. We are developing Hardware and Software.
The management software is a Web product, and is directed to administrative tasks, including, setup of the automation production parameters of products. In true, each product of each company can use several equipments to be produced, like mixers, liquid valves, etc. Eeach hardware haves its own ways to operate. So, for each hardware parameters implementation, I have a small specialist bundle, that provide services for the web application. Latter, this parameters and production orders is delivered to a desktop application that do the hard work Smile.
This management application runs with Virgo Tomcat and Vaadin.
The desktop application:
To control the hardware, we have another application, a desktop one, that runs with JavaFX 2 and Virgo Kernel, that effectivelly manage the production sending commands to our hardware that manages the eletric and eletronic stuff. Each device protocol is implemented as bundles, because each customer and their factorys have different ones.
And it's not only it. We have bundles to integrate to other systems, or to do customer specific tasks, without changing the general core, etc.
It will be mutch harder to develop this, without OSGi!
Previous Topic:osgi:list with a listener to a bean with prototype scope
Next Topic:Problem resolving blueprint.xsd
Current Time: Mon Jul 21 01:22:41 EDT 2025
Powered by FUDForum. Page generated in 0.06479 seconds
