Home » Modeling » Epsilon » Eclipse Epsilon 64bit
Eclipse Epsilon 64bit [message #1110988] Tue, 17 September 2013 11:57 Go to next message
Hy guys,
I downloaded the latest version of Eclipse Epsilon Boundle, 64bit for Linux. Unfortunately when i start it i receive that error:
bash: ./eclipse: cannot execute binary file
It is strange because i have the previous version installed in the same machine and it works well! It's the same for the standard version of the latest Eclipse version.
My OS is Ubuntu 12.04 64bit and I'm using the latest version of oracle jdk as well.
can anyone help me?
Re: Eclipse Epsilon 64bit [message #1111007 is a reply to message #1110988] Tue, 17 September 2013 12:31 Go to previous messageGo to next message
i just tested with the juno based version and everything seems to work fine.... i really don't understand what could be the mistake...
Re: Eclipse Epsilon 64bit [message #1112186 is a reply to message #1111007] Thu, 19 September 2013 04:17 Go to previous messageGo to next message
Sorry, it seems I might have made a mistake while building or uploading the 64-bit version.
The problem is that I'm currently away at a conference and I won't be able to rebuild it until Saturday. If you need it before then, I'd advise downloading the Eclipse 64-bit Modeling distribution and installing Epsilon through our update site.
Again, sorry for the inconvenience Sad.
Re: Eclipse Epsilon 64bit [message #1112272 is a reply to message #1112186] Thu, 19 September 2013 06:45 Go to previous messageGo to next message
No Problem!
I will use the previous one for now hoping the fixed version will be updated soon.
Good work!
Re: Eclipse Epsilon 64bit [message #1114317 is a reply to message #1112272] Sun, 22 September 2013 10:55 Go to previous messageGo to next message
I've just uploaded a new distribution which should be fixed. Could you try it out and let us know if it works for you?
Re: Eclipse Epsilon 64bit [message #1114835 is a reply to message #1114317] Mon, 23 September 2013 05:18 Go to previous messageGo to next message
I've been following this issue, as I had the same problem last week.
The Linux 64bit button now goes to a broken link from http://www.eclipse.org/epsilon/download/ (or rather the file is no longer available).
Re: Eclipse Epsilon 64bit [message #1115247 is a reply to message #1114835] Mon, 23 September 2013 18:14 Go to previous messageGo to next message
Hi Dave,
The link should work fine now - apologies for any inconvenience caused.
Dimitris
Re: Eclipse Epsilon 64bit [message #1115573 is a reply to message #1115247] Tue, 24 September 2013 05:27 Go to previous message
I've tested it right now! it works!
bye!
Previous Topic:[SOLVED] [ECL] how to call lazy rules
Next Topic:[ecl] access to model elements referenced by stub
Current Time: Fri Jul 25 20:49:04 EDT 2025
Powered by FUDForum. Page generated in 0.05441 seconds
