Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Generate ecore model from database?
[Teneo] Generate ecore model from database? [message #1106627] Wed, 11 September 2013 06:45 Go to next message
Hello everyone,
I have used Hibernate before and I know that it is possible to generate from the database structure hibernate classes.
Is something similar possible with Teneo or is there a recommended way to create an ecore model for an existing database?
Thanks in advance.
Re: [Teneo] Generate ecore model from database? [message #1106688 is a reply to message #1106627] Wed, 11 September 2013 08:01 Go to previous messageGo to next message
Hi John,
This topic has come up a few times the past few years. I even tried to start with a contributor on this, but this
initiative didn't continue. It is a fair amount of work I guess (to do it smartly for example detect join tables).
It makes really sense to have this logic but it is some work to do and therefore would need to be contributed (I can
help out in that case) or funded/sponsored.
gr. Martin
On 09/11/2013 12:45 PM, John M. wrote:
> Hello everyone,
> Thanks in advance.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Generate ecore model from database? [message #1111696 is a reply to message #1106688] Wed, 18 September 2013 11:42 Go to previous messageGo to next message
Hello Martin,
sounds really interesting. Are there any stubs from the first "try"?
I think a good start would be the generation of the eclass out of a database. If this works fine add the relations and so on. Smile
Re: [Teneo] Generate ecore model from database? [message #1111860 is a reply to message #1111696] Wed, 18 September 2013 16:57 Go to previous messageGo to next message
Hmm, I did a search, a bit awkard but I can't find any artifacts from this first effort... it is from many years back.
I totally agree that a first step would generate the eclass. So using the database metadata generate eclasses and some
ereferences (based on foreign keys). A next step/future thing is to generate JPA annotations in the generated ecore to
support mapping of the ecore to the original database model.
Other future topic is to support some name mapping from database technical names to readable names. Sometimes in the
dbschema there are very technical names or name length limitations, while in the model you want readable names.
Let me know if you need some help or if you want me to review code, or would want to cooperate in a different way, you
can always drop me a direct email to discuss more. Whatever works best for you!
gr. Martin
On 09/18/2013 05:42 PM, John M. wrote:
> Hello Martin,
> so on. :)
The Netherlands
Re: [Teneo] Generate ecore model from database? [message #1122595 is a reply to message #1106627] Tue, 01 October 2013 14:55 Go to previous messageGo to next message
MoDisco already has some support for reverse engineering SQL databases. I haven't played around with it that much, but perhaps it could be helpful for your use case.
cheers,
Miles
Re: [Teneo] Generate ecore model from database? [message #1130014 is a reply to message #1122595] Wed, 09 October 2013 02:37 Go to previous messageGo to next message
I have actually written a DB "sniffer" some time ago, it was for the first release of JDO (2001 ?).
It generated a model of the database, a default corresponding object model, a mapping and the JDO object classes, already enhanced in source code.
What would be required to do is design a new ecore model of a RDB schema (maybe it already exists ?) and define standard ecore annotations for the mapping.
Would it be useful for you as a start point, or just as a source of inspiration ?
Re: [Teneo] Generate ecore model from database? [message #1130555 is a reply to message #1130014] Wed, 09 October 2013 13:49 Go to previous message
@Miles:
Thanks for the hint with MoDisco, but I don't find a "real" solution how to import from a database.
@Gordan:
I think it would be a good start point, but I am new to this business. Smile
Previous Topic:[ EEF ] View composition
Next Topic:[Teneo] (rewritten question): Resource is empty on read, despite DB populated correctly
Current Time: Sat Jul 26 11:55:27 EDT 2025
Powered by FUDForum. Page generated in 0.17015 seconds
