Home » Eclipse Projects » Remote Application Platform (RAP) » How to change themes per-user?
How to change themes per-user? [message #1111598] Wed, 18 September 2013 08:42 Go to next message
Is it possible to serve two different themes to two users within one RAP/RWT application instance?
A use case would be to display different logo/title/colors to users based on their organization in a multi-branded cloud web app.
Re: How to change themes per-user? [message #1112149 is a reply to message #1111598] Thu, 19 September 2013 03:23 Go to previous messageGo to next message
Hi David,
branding (theming) is attached to the entrypoint (servlet path). You
could register two entry points (same class) with different themes:
Map<String, String> properties = new HashMap<String, String>();
properties.put( WebClient.THEME_ID, "foo" );
application.addEntryPoint( "/foo", MyEntry.class, properties );
properties.put( WebClient.THEME_ID, "bar" );
application.addEntryPoint( "/bar", MyEntry.class, properties );
application.addStyleSheet( "foo", "theme/foo.css" );
application.addStyleSheet( "bar", "theme/bar.css" );
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: How to change themes per-user? [message #1112194 is a reply to message #1112149] Thu, 19 September 2013 04:32 Go to previous messageGo to next message
Thanks, Ivan. This allows to reuse the same entry point class with different paths and themes. This will force me, however, to a) add extra path level to all URLs and b) create new path for every new group of users with custom theme.
Searching more forums, I've found class
org.eclipse.rap.rwt.internal.theme.ThemeUtil
with method
setCurrentThemeId(UISession uiSession, String themeId)
- a per-session theme setting! The signature is just what I need, but unfortunately it did not work (I was setting theme and called relayout of main shell in button selection handler). Ultimately, I'd like to set a theme for user after he logs in without adding extra paths, if possible.
I've also found some mentions that switching theme in runtime was not possible in 1.2 (2008-2009), could it possibly change?
Re: How to change themes per-user? [message #1112215 is a reply to message #1112194] Thu, 19 September 2013 05:01 Go to previous messageGo to next message
Hi David,
switching theme in runtime is still not possible and it's not in our
plan to impplement for RAP 2.2-2.3. Using different servlet paths is the
only way to go.
Best,
Ivan
> org.eclipse.rap.rwt.internal.theme.ThemeUtil with method
> setCurrentThemeId(UISession uiSession, String themeId) - a per-session
Ivan Furnadjiev
Re: How to change themes per-user? [message #1129001 is a reply to message #1112215] Tue, 08 October 2013 03:40 Go to previous messageGo to next message
We also have a similar need. In our case the application administrator is the one choosing the theme and the theme has to be applied to all users connecting to the platform.
In this case having an URL per theme is no really acceptable.
I wasn't able to find an enhancement request/bug talking about this should I create one?
Re: How to change themes per-user? [message #1129059 is a reply to message #1129001] Tue, 08 October 2013 04:43 Go to previous messageGo to next message
Hi Sebastien,
yes... Please open an enhancement request.
Ivan
On 10/8/2013 10:40 AM, Sebastien Arod wrote:
Ivan Furnadjiev
Re: How to change themes per-user? [message #1131140 is a reply to message #1129059] Thu, 10 October 2013 04:28 Go to previous message
Hi Ivan,
I created ER 419098 [Theming] Support changing theme without changing url
-Seb
[Updated on: Thu, 10 October 2013 04:29] by Moderator
Previous Topic:Nested Tables in RAP applications
Next Topic:Fileupload Incubator for RAP 2.2
Current Time: Fri Jul 25 19:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.03832 seconds
