Home » Newcomers » Newcomers » problem with slow ant builds
problem with slow ant builds [message #110280] Wed, 19 October 2005 17:18 Go to next message
Originally posted by: pfink.wmode.com
I am trying to build my project with ant and it works very slow. For
instance my co-worker can do the build of the project in 30 seconds whereas
it takes me 10 minutes. Does anyone have any ideas on what the problem could
be?
Re: problem with slow ant builds [message #111133 is a reply to message #110280] Mon, 24 October 2005 12:15 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
You can try getting a heap dump from Java to see where the time is
going. Ctrl+Break on the Java console in Windows, or kill -3 to the
java process on *nix platforms. Without this kind of information it is
hard to give further advice.
Paul wrote:
> be?
> Thanks
Re: problem with slow ant builds [message #111285 is a reply to message #111133] Mon, 24 October 2005 15:41 Go to previous messageGo to next message
I am running the build.xml file within eclipse. Is there any way I can get
the heap dump using this?
"John Arthorne" <john@eclipsefaq.org> wrote in message
news:djj1bq$q4f$3@news.eclipse.org...
> You can try getting a heap dump from Java to see where the time is going.
> Ctrl+Break on the Java console in Windows, or kill -3 to the java process
> on *nix platforms. Without this kind of information it is hard to give
> further advice.
> Paul wrote:
>> Hi,
>> whereas it takes me 10 minutes. Does anyone have any ideas on what the
>> problem could be?
>> Thanks
Re: problem with slow ant builds [message #111359 is a reply to message #111133] Mon, 24 October 2005 18:06 Go to previous messageGo to next message
Ok I figured out how to get it to run in the console in Windows
This is my heap dump: (Any help would be appreciated)
Full thread dump Java HotSpot(TM) Client VM (1.5.0_05-b05 mixed mode,
sharing):
"Low Memory Detector" daemon prio=5 tid=0x00a6f2b8 nid=0x968 runnable
[0x00000000..0x00000000]
"CompilerThread0" daemon prio=10 tid=0x00a6dfc0 nid=0x678 waiting on
condition [0x00000000..0x02c0f84c]
"Signal Dispatcher" daemon prio=10 tid=0x00a6d128 nid=0x9d8 waiting on
condition
"Finalizer" daemon prio=9 tid=0x00a48490 nid=0xa0c in Object.wait()
[0x02b8f000..0x02b8fc68]
at java.lang.Object.wait(Native Method)
- waiting on <0x22f7cbf8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:116)
- locked <0x22f7cbf8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:132)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 59)
"Reference Handler" daemon prio=10 tid=0x00a47008 nid=0xec0 in Object.wait()
[0x02b4f000..0x02b4fce8]
- waiting on <0x22f7cc78> (a java.lang.ref.Reference$Lock)
at java.lang.Object.wait(Object.java:474)
at java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 116)
- locked <0x22f7cc78> (a java.lang.ref.Reference$Lock)
"main" prio=5 tid=0x00036890 nid=0x104 runnable [0x0007e000..0x0007fc3c]
at java.util.zip.ZipFile.close(Native Method)
at java.util.zip.ZipFile.close(ZipFile.java:481)
- locked <0x22a83b40> (a java.util.jar.JarFile)
at
com.sun.tools.javac.util.Paths$Path.addJarClassPath(Paths.ja va:254)
at com.sun.tools.javac.util.Paths$Path.addFile(Paths.java:223)
at com.sun.tools.javac.util.Paths$Path.addFiles(Paths.java:205)
at com.sun.tools.javac.util.Paths$Path.addFiles(Paths.java:210)
at
com.sun.tools.javac.util.Paths.computeUserClassPath(Paths.ja va:307)
at com.sun.tools.javac.util.Paths.lazy(Paths.java:78)
at com.sun.tools.javac.util.Paths.bootClassPath(Paths.java:91)
at com.sun.tools.javac.jvm.ClassReader.fillIn(ClassReader.java: 1901)
at
com.sun.tools.javac.jvm.ClassReader.complete(ClassReader.jav a:1538)
at com.sun.tools.javac.code.Symbol.complete(Symbol.java:355)
at com.sun.tools.javac.comp.Enter.visitTopLevel(Enter.java:249)
at com.sun.tools.javac.tree.Tree$TopLevel.accept(Tree.java:382)
at com.sun.tools.javac.comp.Enter.classEnter(Enter.java:214)
at com.sun.tools.javac.comp.Enter.classEnter(Enter.java:228)
at com.sun.tools.javac.comp.Enter.complete(Enter.java:441)
at com.sun.tools.javac.comp.Enter.main(Enter.java:426)
at
com.sun.tools.javac.main.JavaCompiler.compile(JavaCompiler.j ava:413)
at com.sun.tools.javac.main.Main.compile(Main.java:592)
at com.sun.tools.javac.main.Main.compile(Main.java:544)
at com.sun.tools.javac.Main.compile(Main.java:67)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.apache.tools.ant.taskdefs.compilers.Javac13.execute(Java c13.java:55)
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:931)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:757)
at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at
org.apache.tools.ant.helper.SingleCheckExecutor.executeTarge ts(SingleCheckExecutor.java:37)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:382)
at
org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at
at
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at org.apache.tools.ant.Main.runBuild(Main.java:668)
at org.apache.tools.ant.Main.startAnt(Main.java:187)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:246)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:67)
"VM Thread" prio=10 tid=0x00a686f8 nid=0x5cc runnable
"VM Periodic Task Thread" prio=10 tid=0x00a70638 nid=0xa14 waiting on
condition
> further advice.
> Paul wrote:
>> Hi,
>> problem could be?
>> Thanks
Re: problem with slow ant builds [message #111936 is a reply to message #111359] Tue, 25 October 2005 10:32 Go to previous message
Well, it's deep inside the Sun Java compiler, which I know nothing
about. It looks like in this particular snippet it is performing
classpath computations... one thing that can seriously affect compile
performance is the location of the JARs on your classpath. I.e., are
they on a network drive on a slow connection, on a local drive, etc.
Compiling against a classpath that is entirely on your local disk is
generally quite a lot faster than compiling against JARs located
elsewhere. I don't know what else to suggest, other than trying to
eliminate the variables between your machine and your colleague's
machine to see what difference is causing the huge discrepancy in
compile time.
> sharing):
> condition
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> condition
>>further advice.
>>Paul wrote:
>>>Hi,
>>>problem could be?
>>>Thanks
Previous Topic:How to construct an IFile?
Next Topic:Properties Not Displaying
Current Time: Tue Jul 22 01:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.09704 seconds
