[Solved][Eugenia] Patches [message #1100781] |
Tue, 03 September 2013 11:25  |
I'm learning using Eugenia patches functionality. For this purpose I'm following the tutorial described on http://www.eclipse.org/epsilon/doc/articles/print.php?articleId=eugenia-patching. I have executed the first part of the tutorial successfully, modifying generated code with different customized patches. But the problem comes on the second part, where the patches are generated from a .egx file. I have specified both egx and egl files but if I execute "Generate patches" Eugenia action, the following error appears:
Could not process 'C:\Users\xdecarlos\Desktop\Kepler_Sep\runtime\runtime-New_configuration\es.ikerlan.example\model\FixCustomEditPartTemplate.egl'
Cause: java.net.MalformedURLException: unknown protocol: c
at org.eclipse.epsilon.egl.EglTemplateFactory.handleFailedLoad(EglTemplateFactory.java:205)
Maybe I have done something wrong, but I don't know where. Any suggestion?
Thank you!
Xabier De Carlos.
[Updated on: Mon, 23 September 2013 05:17] by Moderator
FUDForum. Page generated in 0.06215 seconds
