Home » Modeling » Epsilon » [Solved][Eugenia] Patches
[Solved][Eugenia] Patches [message #1100781] Tue, 03 September 2013 11:25 Go to next message
I'm learning using Eugenia patches functionality. For this purpose I'm following the tutorial described on http://www.eclipse.org/epsilon/doc/articles/print.php?articleId=eugenia-patching. I have executed the first part of the tutorial successfully, modifying generated code with different customized patches. But the problem comes on the second part, where the patches are generated from a .egx file. I have specified both egx and egl files but if I execute "Generate patches" Eugenia action, the following error appears:
Could not process 'C:\Users\xdecarlos\Desktop\Kepler_Sep\runtime\runtime-New_configuration\es.ikerlan.example\model\FixCustomEditPartTemplate.egl'
	Cause: java.net.MalformedURLException: unknown protocol: c
	at org.eclipse.epsilon.egl.EglTemplateFactory.handleFailedLoad(EglTemplateFactory.java:205)
Maybe I have done something wrong, but I don't know where. Any suggestion?
Thank you!
Xabier De Carlos.
[Updated on: Mon, 23 September 2013 05:17] by Moderator
Re: Eugenia patches [message #1101307 is a reply to message #1100781] Wed, 04 September 2013 05:27 Go to previous messageGo to next message
Hi Xabier,
This looks like a Windows/*nix path issue. I'll try the example on my Windows machine and get back to you.
Dimitris
Re: Eugenia patches [message #1110865 is a reply to message #1101307] Tue, 17 September 2013 08:35 Go to previous messageGo to next message
Hi Dimitris,
I have prepared here a small example where error also appears. This example modifies with patches node size at editpart of each node of the metamodel. I attach here the code.
Thank you,
Xabi.
[Updated on: Tue, 17 September 2013 08:36] by Moderator
Re: Eugenia patches [message #1111022 is a reply to message #1110865] Tue, 17 September 2013 12:56 Go to previous messageGo to next message
Hi Xabi,
Apologies for the radio silence (time flies!). I'll try to have a look at this later on today.
Dimitris
Re: Eugenia patches [message #1111186 is a reply to message #1111022] Tue, 17 September 2013 19:15 Go to previous messageGo to next message
Hi Xabi,
This seems to be a bug indeed. Please file a bug report and we'll try to fix this as soon as possible.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=epsilon
Dimitris
Re: Eugenia patches [message #1111207 is a reply to message #1111186] Tue, 17 September 2013 20:00 Go to previous messageGo to next message
Hi Xabi,
No need to do this. I've filed a bug [1], fixed it and released a new interim version.
Dimitris
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=417462
icon14.gif  Re: Eugenia patches [message #1111404 is a reply to message #1111207] Wed, 18 September 2013 02:59 Go to previous message
Hi Dimitris,
Eugenia patch generation running successfully! Very Happy
Thank you!
Xabi.
Previous Topic:[Eugenia] Eclipse Kepler & SVG
Next Topic:How to handle validation problems?
Current Time: Sun Jul 27 07:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.05830 seconds
