[Eugenia] Eclipse Kepler & SVG [message #1108941] |
Sat, 14 September 2013 12:59  |
Hi all,
I am testing the bundle Eclipse Epsilon with Eugenia. I have
implemented some examples of Eugenia/GMF editors which use SVG image files.
In order to use this characteristic, with Juno I had to install the
GMF Tooling Experimental. I tried to do this with Kepler but I have
found some problems, and the result is that I have errors when I
generate the editor. Concretely, the problems arise in the generated
..diagram project (Eclipse cannot find the bundle relate to gmf tooling
experimental
Has anyone tested this Eugenia/GMF feature with Kepler? Is it
possible to use SVG image files in the Eugenia release for Kepler?
Thanks in advance,
Toñi
FUDForum. Page generated in 0.05559 seconds
