V1.1.0M1 and V1.1.0M2 handling of new document type plugin's css [message #1107508] |
Thu, 12 September 2013 10:05  |
I've checked out new versions V1.1.0M1 and V1.1.0M2 with my previusly created document type plugin and sadly I found both can't handle my plugin's css as V1.0.0 did.
I have check out if extension mechanisms have not changed so I've looked into org.eclipse.vex.docbook bundle to find out differences. I have not found any changes which can in my opinion makes some killer difference.
Symptoms are: It renders for e.g. tables or headings but it stops rendering other blocks after one is rendered. So I get only heading or only table and rest of document is not rendered. I also encountered another problem with tables, since I can't place cursor inside the table starting M1.
PS: I have tried Juno and Kepler both fresh RPC bundle installations. Since I have found interface for OutlineProvider changed I have removed it from extension point.
BTW why V1.1.0M2 is restricted for Kepler as minumum? Have you encountered some problems with Juno?
Thanks for your help
Best Regards Jan Kantor
FUDForum. Page generated in 0.10675 seconds
