Home » Eclipse Projects » NatTable » Changing parent of a node in the tree table
Changing parent of a node in the tree table [message #1110106] Mon, 16 September 2013 07:33 Go to next message
I have populated my Tree Table, with some nodes.
Before adding these nodes to the table, I assign them their parent (if any), then add them to the Table.(event list actually).
For example:
Node node = new Node();
node.setParent(parentNode);
eventList.add(node);
Something like that!
Anyways, what I need to do is that when I change its parent to some other node, it should be a child of some other node and reflected in the Tree Table.
But it stays the child of the same node.
For example:
Before
-Parent1:
--Child1
--Child2
Child2 is child of Parent1.
After I make Child2 a child of Child1, the result stays the same:
-Parent1:
--Child1
--Child2
Instead of:
-Parent1:
--Child1
---Child2
Is this some restriction in the table, or am I doing something wrong?
Ali Ahmad Malik
Re: Changing parent of a node in the tree table [message #1110213 is a reply to message #1110106] Mon, 16 September 2013 10:46 Go to previous messageGo to next message
Haven't worked on such cases. Are you sure the TreeList reflects your modifications correctly? And if so, do you perform a refresh after your modifications?
Re: Changing parent of a node in the tree table [message #1110821 is a reply to message #1110213] Tue, 17 September 2013 07:16 Go to previous messageGo to next message
I did refresh the NatTable after doing that, but no use.
I am not sure where does the problem lie, after changing the parent I also tried:
        sortedList = new SortedList<IDSTreeTableNode>(eventList, null);
        treeList = new TreeList<IDSTreeTableNode>(sortedList,
        		treeTableFormat, expansionModel);
        treeData = new DSTreeTableData(treeList);
        treeRowModel = new GlazedListTreeRowModel<IDSTreeTableNode>(treeData);
This should have changed the TreeList, too. I will try and debug for the TreeList now.
Any suggestions?
Re: Changing parent of a node in the tree table [message #1110850 is a reply to message #1110821] Tue, 17 September 2013 08:03 Go to previous message
Not quite sure, did you check your TreeList.Format and TreeList.ExpansionModel?
Previous Topic:checkbox problem
Next Topic:Sorting in Tree List Breaks the Tree Structure
Current Time: Thu Jul 24 17:45:48 EDT 2025
Powered by FUDForum. Page generated in 0.03623 seconds
