| Error trying to set new file into editor - NullPointerException [message #110970] |
Wed, 16 November 2005 13:30  |
I'm getting this error on two projects, but one other works fine. All
projects were built with a prior release of Eclipse and VE. I tried
VE1.0.xx, but still getting the error. I Googled this as much as I could,
without success as to a resolution. I'm getting a tad nervous, as one of
the projects is getting active again.
| Re: Error trying to set new file into editor - NullPointerException [message #611330 is a reply to message #110970] |
Wed, 16 November 2005 13:35  |
Try the following (we want to clear out any caches):
1) Open a VE and then close it. Make sure there are NO VE's open at all.
2) Clear the .log file (use the ErrorLog view and the "Delete Log" button).
3) Projects->Clean...->Clean ALL projects radio button
4) Wait for build to finish
5) Try opening the VE again.
If you still get errors, please send us this new log.
> could, without success as to a resolution. I'm getting a tad nervous,
> as one of the projects is getting active again.
Rich Kulp
| Re: Error trying to set new file into editor - NullPointerException [message #611331 is a reply to message #110995] |
Wed, 16 November 2005 13:47  |
As requested:
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.15
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NoClassDefFoundError: java/util/regex/Pattern
at
org.eclipse.jem.internal.beaninfo.common.FeatureAttributeVal ue. <clinit>(FeatureAttributeValue.java:170)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.fill(M odelingBeanInfo.java:809)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.sendPr opertyDecorators(ModelingBeanInfo.java:623)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:550)
at java.lang.reflect.Method.invoke(Native Method)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
at
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility.introspect(BeanInfoDecoratorUtility.java:215)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:762)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:429)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:416)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:637)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEStructuralFeatures(BeaninfoClassAdapter.java:1184)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEStructu ralFeatures(JavaClassImpl.java:394)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getProperti es(JavaClassImpl.java:1308)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:1313)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllProperties(BeaninfoClassAdapter.java:1192)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllPrope rties(JavaClassImpl.java:1349)
at
org.eclipse.ve.internal.java.codegen.java.rules.ThisReferenc eRule.useInheritance(ThisReferenceRule.java:114)
at
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.create ThisIfNecessary(TypeVisitor.java:115)
at
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:238)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:512)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:835)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:917)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1920)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:38.78
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:38 PST 2005 Feature
"java.awt.Component->bounds" did not have a type set. Typically due to
override file creating feature but property not found on
introspection/reflection.
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:38.93
!MESSAGE
"java.awt.Component->location" did not have a type set. Typically due to
!MESSAGE
"java.awt.Component->size" did not have a type set. Typically due to
!MESSAGE
"java.awt.Component->componentOrientation" did not have a type set.
Typically due to override file creating feature but property not found on
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:38.265
!MESSAGE Exception thrown.
!STACK 0
java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(Unknown Source)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(Unk nown
Source)
at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
at java.io.ObjectInputStream.<init>(Unknown Source)
at
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility$ProxyIntrospectCallBack.calledBackStream(BeanInfoDec oratorUtility.java:351)
at
org.eclipse.jem.internal.proxy.remote.REMCallbackThread.run( REMCallbackThread.java:276)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.328
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:38 PST 2005 Project (Employee Self
Service Update)-Beaninfo:err>
IWAV0123E --------- UNCAUGHT EXCEPTION ---------
java.lang.Error: java.beans.IntrospectionException: IWAV0010E Cannot
find at least the write or read accessor for property
focusTraversalPolicy. IWAV0147E Cannot create the PropertyDescriptor for
at
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.throwError(BaseBean Info.java:837)
at
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.createPropertyDescr iptor(BaseBeanInfo.java:473)
at
org.eclipse.ve.internal.jfc.beaninfo.ContainerBeanInfo.getPr opertyDescriptors(ContainerBeanInfo.java:557)
at
java.beans.Introspector.getTargetPropertyInfo(Introspector.j ava:374)
at java.beans.Introspector.getBeanInfo(Introspector.java:324)
at java.beans.Introspector.getBeanInfo(Introspector.java:106)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.intros pect(ModelingBeanInfo.java:189)
at
at
java.lang.Error: java.lang.NoSuchMethodException:
getFocusTraversalPolicy IWAV0007E Cannot get the method
getFocusTraversalPolicy.
at
at
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.createMethodDescrip tor(BaseBeanInfo.java:313)
at
org.eclipse.ve.internal.jfc.beaninfo.ContainerBeanInfo.getMe thodDescriptors(ContainerBeanInfo.java:492)
at java.beans.Introspector.getTargetMethodInfo(Introspector.jav a:710)
at java.beans.Introspector.getBeanInfo(Introspector.java:326)
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.453
!MESSAGE
!STACK 0
org/eclipse/jem/internal/beaninfo/common/FeatureAttributeVal ue
at
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.sendBe anDecorator(ModelingBeanInfo.java:579)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:548)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.203
!STACK 0
Source)
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.234
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1221)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEvents(J avaClassImpl.java:1314)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2260)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1229)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllEvent s(JavaClassImpl.java:1336)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:64)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:97)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:133)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:346)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:437)
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.250
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:39 PST 2005 Feature
"javax.swing.JComponent->nextFocusableComponent" did not have a type set.
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.296
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.296
!MESSAGE
"javax.swing.AbstractButton->mnemonic" did not have a type set. Typically
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.328
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:39 PST 2005 Project (Employee Self
find at least the write or read accessor for property transferHandler.
IWAV0147E Cannot create the PropertyDescriptor for transferHandler.
at
at
at
org.eclipse.ve.internal.jfc.beaninfo.JComponentBeanInfo.getP ropertyDescriptors(JComponentBeanInfo.java:1446)
at
at
at
at
java.lang.Error: java.lang.NoSuchMethodException: getTransferHandler
IWAV0007E Cannot get the method getTransferHandler.
at
at
at
org.eclipse.ve.internal.jfc.beaninfo.JComponentBeanInfo.getM ethodDescriptors(JComponentBeanInfo.java:1186)
at
at
at
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.343
!STACK 0
Source)
at
at
!STACK 0
Source)
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.343
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.390
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.500
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.562
!MESSAGE
find at least the write or read accessor for property UI. IWAV0147E Cannot
create the PropertyDescriptor for UI.
at
at
at
org.eclipse.ve.internal.jfc.beaninfo.JPanelBeanInfo.getPrope rtyDescriptors(JPanelBeanInfo.java:133)
at
at
at
at
java.lang.Error: java.lang.NoSuchMethodException: getUI IWAV0007E
Cannot get the method getUI.
at
at
at
org.eclipse.ve.internal.jfc.beaninfo.JPanelBeanInfo.getMetho dDescriptors(JPanelBeanInfo.java:89)
at
java.beans.Introspector.getTargetMethodInfo(Introspector.jav a(Compiled
Code))
at
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.609
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.625
!MESSAGE
"javax.swing.JLabel->displayedMnemonic" did not have a type set. Typically
!MESSAGE
"javax.swing.JLabel->labelFor" did not have a type set. Typically due to
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.687
!STACK 0
Source)
at
at
!STACK 0
Source)
at
at
!STACK 0
Source)
at
at
!STACK 0
Source)
at
at
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.718
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.718
!MESSAGE
"javax.swing.text.JTextComponent->text" did not have a type set. Typically
!MESSAGE
"javax.swing.text.JTextComponent->selectionEnd" did not have a type set.
!MESSAGE
"javax.swing.text.JTextComponent->selectionStart" did not have a type set.
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.765
!MESSAGE
find at least the write or read accessor for property navigationFilter.
IWAV0147E Cannot create the PropertyDescriptor for navigationFilter.
at
at
at
org.eclipse.ve.internal.jfc.beaninfo.JTextComponentBeanInfo. getPropertyDescriptors(JTextComponentBeanInfo.java:913)
at
at
FUDForum. Page generated in 0.06127 seconds
