Home » Eclipse Projects » e(fx)clipse » E4 application project with JavaFX: Maven problem
E4 application project with JavaFX: Maven problem [message #1108761] |
Sat, 14 September 2013 06:01  |
I'm trying to build a E4 application project with JavaFX parts with Maven and running into problems.
I've created an "Eclipse 4 Application Project" my.test.app in Juno, created parts etc. It runs fine from Eclipse.
Now I'm trying to build it with Maven, so I've created a separate releng project my.test.app.releng, moved the product file there and converted both to Maven projects. I get a build success when doing a "clean install" on my.test.app (with packaging = pom).
When I try to do a maven build (clean install) on the releng project (with packaging = eclipse-repository) I get a build failure with these error messages:
Failed to execute goal org.eclipse.tycho:tycho-p2-publisher-plugin:0.16.0:publish-products (default-publish-products) on project my.test.app.releng: Exception while publishing product C:\workspace\my.test.app.releng\my.test.app.product: "publishing result": [
"Included element at.bestsolution.efxclipse.runtime.javafx 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element my.test.app 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element at.bestsolution.efxclipse.runtime.osgi 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.aix.ppc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.hpux.ia64_32 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.linux.ppc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.linux.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.linux.x86_64 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.macosx 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.solaris.sparc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.filesystem.win32.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.core.resources.win32.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.carbon.macosx 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.cocoa.macosx 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.cocoa.macosx.x86_64 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.ppc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.ppc64 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.s390 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.s390x 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.linux.x86_64 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.solaris.sparc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.gtk.solaris.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.motif.aix.ppc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.motif.hpux.ia64_32 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.motif.linux.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.motif.solaris.sparc 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.photon.qnx.x86 0.0.0 is missing. Cannot determine filter for requirement to this element.",
"Included element org.eclipse.swt.win32.win32.x86 0.0.0 is missing. Cannot determine filter for requirement to this element."]
-> [Help 1]
I'm new to RCP development and Maven, so I might overlook something obvious...
[Updated on: Mon, 16 September 2013 04:03] by Moderator
Re: E4 application project with JavaFX: Maven problem [message #1109995 is a reply to message #1108761] |
Mon, 16 September 2013 04:10   |
So it is a mixed mode application? SWT & JavaFX?
Packageing should never be pom, not? For bundles it is "eclipse-plugin"!
> (with packaging = eclipse-repository) I get a build failure these error
> messages:
Do you have target-platform-configuration entries in your root-pom.xml?
> for requirement to this element.", "Included element
> determine filter for requirement to this element.", "Included element
> -> [Help 1]
> obvious...
Re: E4 application project with JavaFX: Maven problem [message #1110099 is a reply to message #1109995] |
Mon, 16 September 2013 07:17  |
Thomas Schindl wrote on Mon, 16 September 2013 04:10So it is a mixed mode application? SWT & JavaFX?
I've never heard about "mixed mode" before, but my application has JavaFX parts (injecting javafx.scene.layout.BorderPane) and SWT parts (injecting org.eclipse.swt.widgets.Composite).
Quote:For bundles it is "eclipse-plugin"!
I changed to "eclipse-plugin". Same error messages.
Quote:Do you have target-platform-configuration entries in your root-pom.xml?
I do:
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>target-platform-configuration</artifactId>
<version>${tycho-version}</version>
<configuration>
<environments>
<environment>
<os>win32</os>
<ws>win32</ws>
<arch>x86</arch>
</environment>
</environments>
</configuration>
</plugin>
Current Time: Mon Jul 21 09:47:06 EDT 2025
Powered by FUDForum. Page generated in 0.04002 seconds
