Home » Archived » Mylyn Intent » Synchronization error / not being able to create reference(I am getting synchronization errors and I am not being able to create references)
Synchronization error / not being able to create reference [message #1085198] Mon, 12 August 2013 11:34 Go to next message
Hello there,
I am finally trying to create documentation with Intent and I am not being successful. From the very beginning, I would like to state that I think it's a matter of how to use it, not because a problem with the plugin.
So, my first problems are creating the project itself. The workspace I worked in is based of several maven projects. All of them, despite sharing part of the package name, are completely independent, also in the disk. Let's say that the maven projects are:
com.mydomain.part1Project
com.mydomain.part2Project
They are not stored as
com
mydomain
part1Project
part2Project
but in complete separate folders:
If I try to create an Intent project like
com.mydomain.intentDoc
Eclipse becomes unresponsive and I need kill it finally.
If the intent project name has nothing to do with the other project's names, everything is smooth when creating the project. I think this could have to do with the physical organization of my maven projects...
And maybe this issue is also related with the references.I am not being able to make references to methods. My guess is that the Intent project is not "seeing" the other projects...
Any ideas?
Miguel A.
Re: Synchronization error / not being able to create reference [message #1085656 is a reply to message #1085198] Tue, 13 August 2013 03:21 Go to previous messageGo to next message
Hi Miguel,
first of all, you may want to use the latest Intent nightly
http://download.eclipse.org/intent/updates/nightly/0.8/N201308121238
We made a lot of stability/performance fixes since the June release.
In regards to your deadlock issue, it is pretty ugly, I'll try to
reproduce your deadlock issue ASAP (I've created a blocker bugzilla
issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=414935)
What are you doing to create those references? To reference a Java
method inside an Intent document, you just have to drop the method from
the project explorer (see
https://raw.github.com/eclipse/mylyn.docs.intent.main/master/doc/org.eclipse.mylyn.docs.intent.idoc/html/user/images/intent_06_dropjava.png
or the getting started documentation).
Once this method is linked, you can use hyperlink (F3 or ctrl+click) to
navigate from documentation to code.
If this mechanism does not work, do you have any entry in the error log
that might help me reproducing the issue?
Hope this answers your questions, I'll investigate your deadlock issue ASAP.
Alex
Re: Synchronization error / not being able to create reference [message #1102973 is a reply to message #1085656] Fri, 06 September 2013 04:58 Go to previous messageGo to next message
Hi Alex,
Sorry for the late response... I updated the system to the latest stable Intent version and now Eclipse doesn't hung up when creating the project. So, that part is solved.
But whenever I drag and drop a method to the Intent project I get the following message:
An internal error occurred during: "Synchronizing Repository".
org.eclipse.mylyn.docs.intent.retro.RetroGeneratedElementListener.isExtensionFor(Lorg/eclipse/emf/common/util/URI;)Z
I'll try to update to the latest nightly build and I'll post feedback.
Miguel A.
Re: Synchronization error / not being able to create reference [message #1107595 is a reply to message #1102973] Thu, 12 September 2013 12:52 Go to previous messageGo to next message
Is the stable version newer than the nightly build? It seems so to me. With the last stable version (Mylyn Intent 0.8.1.201308291003) I keep getting the *An internal error occurred during: "Synchronizing Repository"* error every time I try to drag and drop a method. And after clicking on "OK", it happens again every time I save the Intent document.
Any ideas?
Miguel A.
Re: Synchronization error / not being able to create reference [message #1108008 is a reply to message #1107595] Fri, 13 September 2013 03:41 Go to previous messageGo to next message
Hi Miguel,
the error you mentionned in your previous post
references the RetroGeneratedElementListener, which was an example
bridge we wrote for Intent 0.7. It has been removed since we developped
the Java Bridge, and hence has not evolved to match the 0.8 API.
Could you please remove the Retro bridge from your installed plugins?
And yes, the latest stable build (which has been promoted asthe SR1
release of Intent 0.8) includes the most recent developments
http://download.eclipse.org/intent/updates/releases/0.8/R201308291003 .
Please keep me in tuch if you reproduce your issues with the Retro
plugin uninstalled, and sorry for the inconvenience.
Alex
Le 12/09/2013 18:52, Miguel A. Artaso a écrit :
> Any ideas?
> Best regards,
> Miguel A.
Re: Synchronization error / not being able to create reference [message #1108698 is a reply to message #1108008] Sat, 14 September 2013 03:37 Go to previous messageGo to next message
Hi Alex,
I removed the suggested plugin and I no longer get the error! Let's do some Intent-doc Wink
Thanks a lot for your help,
Miguel A.
Re: Synchronization error / not being able to create reference [message #1108749 is a reply to message #1108698] Sat, 14 September 2013 05:34 Go to previous message
Hi Miguel,
great news! Please let me know if you encounter any issue or if some feature is missing for your use case, I'm currently establishing the roadmap for Intent 0.9 http://projects.eclipse.org/projects/mylyn.docs.intent/releases/0.9.0 and it's wide open for your ideas Smile
Alex
Previous Topic:Cannot install Mylyn Intent - CDO support (Incubation)
Next Topic:Intent 0.8 is waiting for your feedback
Current Time: Fri Jul 25 02:07:12 EDT 2025
Powered by FUDForum. Page generated in 0.06909 seconds
