Home » Eclipse Projects » e(fx)clipse » update problem
update problem [message #1105725] |
Tue, 10 September 2013 03:54  |
For the last 3-4 days I was trying to update efxclipse (0.9.0.201309060708) to a newer version (0.9.0.201309100707) using updatesite "http://download.eclipse.org/efxclipse/updates-nightly/site" but I get this error:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.fx.core,0.9.0.201309100602
No repository found containing: osgi.bundle,org.eclipse.fx.core.guice,0.9.0.201309100602
No repository found containing: osgi.bundle,org.eclipse.fx.formats.svg,0.9.0.201309100602
No repository found containing: osgi.bundle,org.eclipse.fx.ide.converter,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.css,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.css.cssext,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.css.cssext.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.css.jfx,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.css.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.fxgraph,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.fxgraph.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.fxml,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.fxml.compiler,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.java6,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.jdt.core,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.jdt.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.model,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.pde.java7,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.pde.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.pde.ui.e4,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.rrobot,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.rrobot.dsl,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.rrobot.dsl.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.rrobot.model,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.ui,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.ide.ui.preview,0.9.0.201309100707
No repository found containing: osgi.bundle,org.eclipse.fx.javafx,2.2.0.201309100602
No repository found containing: osgi.bundle,org.eclipse.fx.osgi,0.9.0.201309100602
No repository found containing: osgi.bundle,org.eclipse.fx.osgi.util,0.9.0.201309100602
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.all.kepler.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.basic.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.converter.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.css.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.fxgraph.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.fxml.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.pde.feature,0.9.0.201309100707
No repository found containing: org.eclipse.update.feature,org.eclipse.fx.ide.rrobot.feature,0.9.0.201309100707
with Kepler 4.3 64Bit running on Win7 64Bit with JDK1.7_u25 64Bit.
I also made a test with a clean new workspace -> same result.
Any ideas why this error shows up?
Thanks for help!
Re: update problem [message #1105749 is a reply to message #1105725] |
Tue, 10 September 2013 04:24   |
Just gave it a try and it worked for me :-(
Tom
On 10.09.13 09:54, Enrico R. wrote:
> Hello,
> action=).
> Thanks for help!
Re: update problem [message #1105788 is a reply to message #1105749] |
Tue, 10 September 2013 05:17   |
You can try using the zipped version and try to install it offline.
http://download.eclipse.org/efxclipse/updates-nightly/site_assembly.zip
Tom
> Tom
>> Hello,
>> action=).
>> Thanks for help!
Current Time: Wed Jul 23 13:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.25686 seconds
