| DataException : Error in saving files of data set cache. [message #1097772] |
Fri, 30 August 2013 02:31  |
We are facing below exception while generating report , Please let us know
what is the exact issue.We have executed the query and dataset is working fine.
error generating report org.eclipse.birt.report.engine.api.EngineException: There is an error in saving files of data set cache.
/apps/GTS/tmp/p_wtydm_wl/ccerrep/cache/DataEngine_698590531_9065/DataSetCacheObject_699656275_5368/data.data (No such file or directory) (Element ID:2026)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1206)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1185)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:260)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
Caused by: org.eclipse.birt.data.engine.core.DataException: There is an error in saving files of data set cache.
at org.eclipse.birt.data.engine.executor.dscache.CacheUtilFactory$DiskSaveUtil.saveObject(CacheUtilFactory.java:183)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.saveDataSetResult(DataSetToCache.java:185)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:1031)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:441)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1495)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:80)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:250)
Caused by: java.io.FileNotFoundException: /apps/GTS/tmp/p_wtydm_wl/ccerrep/cache/DataEngine_698590531_9065/DataSetCacheObject_699656275_5368/data.data (No such file or directory)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
at org.eclipse.birt.data.engine.core.security.FileSecurity$5.run(FileSecurity.java:190)
at org.eclipse.birt.data.engine.core.security.FileSecurity$5.run(FileSecurity.java:1)
at org.eclipse.birt.data.engine.core.security.FileSecurity.createFileOutputStream(FileSecurity.java:186)
at org.eclipse.birt.data.engine.core.security.FileSecurity.createFileOutputStream(FileSecurity.java:170)
at org.eclipse.birt.data.engine.executor.dscache.CacheUtilFactory$DiskSaveUtil.saveObject(CacheUtilFactory.java:178)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.cacheDataSet(ResultSetPopulator.java:205)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.<init>(CachedResultSet.java:142)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
FUDForum. Page generated in 0.04230 seconds
