Home » Modeling » Epsilon » [Kepler] virtualEmf EPackage missing
[Kepler] virtualEmf EPackage missing [message #1106044] Tue, 10 September 2013 11:57 Go to next message
I just changed to Kepler and everytime I run an eclipse instance, I get the following error:
ENTRY org.eclipse.epsilon.common.dt 4 0 2013-09-10 17:55:05.008
!MESSAGE Exception encountered whilst trying to retrieve EPackage for nsUri: virtualEmf
!STACK 0
org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: org.eclipse.epsilon.emc.emf.virtual.VirtualPackage cannot be found by org.eclipse.epsilon.emc.emf.virtual_1.1.0.201308291446
	at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:278)
	at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.getEPackage(EPackageRegistryCache.java:121)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.refreshCurrentRegistry(EPackageRegistryCache.java:114)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.<init>(EPackageRegistryCache.java:37)
	at org.eclipse.epsilon.concordance.reporter.metamodel.MetamodelChangeReporter.<init>(MetamodelChangeReporter.java:25)
	at org.eclipse.epsilon.concordance.dt.ConcordancePlugin.<init>(ConcordancePlugin.java:28)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:282)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:278)
	at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(EarlyStartupRunnable.java:117)
	at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
	at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.ClassNotFoundException: org.eclipse.epsilon.emc.emf.virtual.VirtualPackage cannot be found by org.eclipse.epsilon.emc.emf.virtual_1.1.0.201308291446
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.emf.common.CommonPlugin$Implementation.loadClass(CommonPlugin.java:254)
	at org.eclipse.emf.common.CommonPlugin.loadClass(CommonPlugin.java:96)
	at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:271)
	... 41 more
Any workarounds for this yet?
Re: [Kepler] virtualEmf EPackage missing [message #1106047 is a reply to message #1106044] Tue, 10 September 2013 12:02 Go to previous messageGo to next message
Hi Phil,
It appears that you've hit bug #416828 which has been fixed in the latest interim version.
Dimitris
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=416828
[Updated on: Tue, 10 September 2013 12:03] by Moderator
Re: [Kepler] virtualEmf EPackage missing [message #1106584 is a reply to message #1106047] Wed, 11 September 2013 05:30 Go to previous messageGo to next message
Hi Dimitris,
yep that seems to be the problem. How can I install the latest interm version in eclipse? Have I got to uninstall the stable Epsilon core and then install the Epsilon core from the interim version?
phil
[Updated on: Wed, 11 September 2013 05:33] by Moderator
Re: [Kepler] virtualEmf EPackage missing [message #1106607 is a reply to message #1106584] Wed, 11 September 2013 06:06 Go to previous messageGo to next message
We've just released a new stable release (1.1 SR1) to fix these urgent bugs. You should be able to upgrade with the standard Eclipse facilities, using the stable update site:
http://download.eclipse.org/epsilon/updates/
Re: [Kepler] virtualEmf EPackage missing [message #1106631 is a reply to message #1106607] Wed, 11 September 2013 06:49 Go to previous message
Everything works now, thank you!
Previous Topic:[EVL] Provide variable to EvlModule
Next Topic:[Eugenia] Don't generate specific extension points
Current Time: Fri Jul 25 19:54:01 EDT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
