Home » Modeling » TMF (Xtext) » Hyperlink customization
Hyperlink customization [message #1105832] Tue, 10 September 2013 06:31 Go to next message
Here is my problem, I am developing a RCP which contains a variables navigator (contained in a database). I want to allow ctrl-clic on a variable in a DSL file and provide an hyperlink to either :
- The declaration of the variable in the same file
- The variable in the navigator
I am already sure that there is only one possibility, the redefinition of variable is not allowed by the validator, so I will have only one choice given a variable name.
I have some trouble customizing the HyperlinkHelper. In some way, I need to default cross-reference to link to variable in the same file, but I also need to override it to link to the navigator. My grammar is cross-reference-free, so I need to reimplement it to link to the same file.
For now, I have this in my UIModule :
	public Class<? extends DefaultHyperlinkDetector> bindDefaultHyperlinkDetector() {
		return DSLLinkDetector.class;
	public Class<? extends IHyperlinkHelper> bindIHyperlinkHelper() {
		return DSLLinkHelper.class;
My DSLLinkHelper is like this :
	public void createHyperlinksByOffset(XtextResource resource, int offset,
			IHyperlinkAcceptor acceptor) {
// Handle of the link to the navigator
// If not link to navigator found, try in the same file
                                final URIConverter uriConverter = resource.getResourceSet()
						.getURIConverter();
				final URI uri = EcoreUtil.getURI(target);
				final URI normalized = uri.isPlatformResource() ? uri
						: uriConverter.normalize(uri);
				//System.out.println("URI = " + normalized);
				XtextHyperlink result = getHyperlinkProvider().get;
				result.setHyperlinkRegion(new Region(adapter.getOffset() -10 ,
						adapter.getLength()));
				result.setURI(normalized);
				result.setHyperlinkText("variable");
				acceptor.accept(result);
Here, I have an NullPointerException when I do getHyperlinkProvider().get. I suspect that the @Inject did not go well in the XtextHyperlink.
When I instantiate a new XtextHyperlink(); instead, the NullPointerException appears when I "ctrl+clic" and the open() of XtextHyperLink. Again, I think this is because the
@Inject
private IURIEditorOpener uriEditorOpener;
did not go well because of the inject.
Any idea why ?? Or any idea how to do what I want ?
Thanks !
Re: Hyperlink customization [message #1106135 is a reply to message #1105832] Tue, 10 September 2013 14:59 Go to previous messageGo to next message
sorry have no idea,
can you come up with a complete example
(grammar ...)
Re: Hyperlink customization [message #1106525 is a reply to message #1106135] Wed, 11 September 2013 04:02 Go to previous messageGo to next message
My grammar is ~1000 lines big, so it won't help.
What I have is something like
variable: IDENTIFIER
variableDeclaration: IDENTIFIER
As my proposal provider and validator are different from the default ones, I could not simply use cross-references since I have to check if the variable is declared in my DB as well as in the code. If I use cross-ref, a variable that is not define in the code will always considered as error even if it present in the DB (and my validator checks for it). In conclusion, I must use simply an IDENTIFIER and implement my own proposal provider and validator. These two work well.
The problem comes for the hyperlinks. I managed to override the default hyperlinkHelper and I could put some code to select the variable in my navigator. My problem is I also want to hyperlink to the declaration in the code. In short, I have to reimplement the default hyperlink helper that is used when cross-references happen.
Re: Hyperlink customization [message #1106565 is a reply to message #1106525] Wed, 11 September 2013 05:01 Go to previous messageGo to next message
Hi I thought of a simple example with a dummy grammar
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Hyperlink customization [message #1106687 is a reply to message #1106565] Wed, 11 September 2013 08:04 Go to previous messageGo to next message
Ok, let's go with something like this :
program: variableDeclarations? variableAssignationsList ;
variableDeclarations: "VAR" variableDeclarationList "END_VAR";
variableDeclarationsList: variableDeclaration ';' (variableDeclarationsList)?;
variableDeclaration: IDENTIFIER;
variableAssignationsList: variableAssignation ';' (variableAssignationsList)?;
variableAssignation: IDENTIFIER '=' INT;
I want to manually implement cross-references from variableAssignation to variableDeclaration, in a way that the IDENTIFIER must be declared before being assigned. I can't use cross-references in my grammar, because variableDeclaration can be in a database and the use of cross-references gives error for each variable that is not declared in variableDeclaration.
[Updated on: Wed, 11 September 2013 08:06] by Moderator
Re: Hyperlink customization [message #1106696 is a reply to message #1106687] Wed, 11 September 2013 08:13 Go to previous messageGo to next message
Hi as I said I want code I can copy and paste so why don't you copy
and paste create a small example
Re: Hyperlink customization [message #1106774 is a reply to message #1106696] Wed, 11 September 2013 10:29 Go to previous messageGo to next message
Here's my grammar :
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
program: vd=variableDeclarations? va=variableAssignationsList ;
variableDeclarations: {variableDeclarations} "VAR" vdl=variableDeclarationsList "END_VAR";
variableDeclarationsList: {variableDeclarationList} vd=variableDeclaration ';' (vdl=variableDeclarationsList)?;
variableDeclaration: {variableDeclaration} name=ID;
variableAssignationsList: {variableAssignationList} va=variableAssignation ';' (val=variableAssignationsList)?;
variableAssignation: {variableAssignation} name=variableName '=' INT;
variableName: {variableName} name=ID;
Here's my MyDslUIModule :
public class MyDslUiModule extends org.xtext.example.mydsl.ui.AbstractMyDslUiModule {
	public MyDslUiModule(AbstractUIPlugin plugin) {
		super(plugin);
		return MyDslLinkDetector.class;
		return MyDslLinkHelper.class;
Here's my new LinkDetector :
public class MyDslLinkDetector extends DefaultHyperlinkDetector {
	public IHyperlink[] detectHyperlinks(ITextViewer textViewer,
			IRegion region, boolean canShowMultiplehyperlinks) {
		this.setHelper(new MyDslLinkHelper());
		return super.detectHyperlinks(textViewer, region,
				canShowMultiplehyperlinks);
Here's my new LinkHelper:
public class MyDslLinkHelper extends HyperlinkHelper {
		EObjectAtOffsetHelper eObjectAtOffsetHelper = new EObjectAtOffsetHelper();
		EObject eObject = eObjectAtOffsetHelper.resolveElementAt(resource, offset);
		if (eObject instanceof variableName) {
			variableName variableName = (variableName) eObject;
			CompositeNode adapter = (CompositeNode) NodeModelUtils.getNode(variableName);
			Region region = new Region(adapter.getOffset(), adapter.getLength());
			final URIConverter uriConverter = resource.getResourceSet().getURIConverter();
			final String hyperlinkText = "Variable";
			final URI uri = EcoreUtil.getURI( *** );
			final URI normalized = uri.isPlatformResource() ? uri : uriConverter.normalize(uri);
			XtextHyperlink result = new XtextHyperlink(); // Does not show link with getHyperlinkProvider().get()
			result.setHyperlinkRegion(region);
			result.setHyperlinkText(hyperlinkText);
For the last one, I have two problems. First, I do not know how to get the URI of the variable declaration corresponding to the variable use. And, I can not use the hyperlink provider from HyperLinkHelper (see comment), otherwise the link do not show up. If I use a new Hyperlink provider, the link is shown. But as, there is not URI, there is no effect when I clic on it.
Re: Hyperlink customization [message #1106787 is a reply to message #1106774] Wed, 11 September 2013 10:47 Go to previous messageGo to next message
without looking at the code:
you can get the URI using EcoreUtil.getURI(object)
if you use new XtextHyperlink() the hyperlink will not have an uriopener right?
this should result in an NPE.
Re: Hyperlink customization [message #1106791 is a reply to message #1106787] Wed, 11 September 2013 10:55 Go to previous messageGo to next message
Btw why this:
of course you will get an npe !
=> simply use the defaulthyperlink detector.
Re: Hyperlink customization [message #1107388 is a reply to message #1106791] Thu, 12 September 2013 06:23 Go to previous message
Thanks a lot for these remarks, I got it working !!
Very Happy
Previous Topic:import ecore model using nsURI
Next Topic:Eopposite Reference in Xtext
Current Time: Sun Jul 20 22:00:09 EDT 2025
Powered by FUDForum. Page generated in 0.06013 seconds
