Home » Modeling » Epsilon » org.eclipse.epsilon.emc.emf.virtual problem(org.eclipse.epsilon.emc.emf.virtual.VirtualPackage cannot be found by org.eclipse.epsilon.emc.emf.virtual_1.1.0.201308291446)
org.eclipse.epsilon.emc.emf.virtual problem [message #1105007] Mon, 09 September 2013 04:10 Go to next message
Hi all when i get update today i always get this problem when i generate gmf project
i dont understand this problem anyone get this before ?
Exeption;
org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: org.eclipse.epsilon.emc.emf.virtual.VirtualPackage cannot be found by org.eclipse.epsilon.emc.emf.virtual_1.1.0.201308291446
	at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:278)
	at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.getEPackage(EPackageRegistryCache.java:121)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.refreshCurrentRegistry(EPackageRegistryCache.java:114)
	at org.eclipse.epsilon.concordance.reporter.metamodel.EPackageRegistryCache.<init>(EPackageRegistryCache.java:37)
	at org.eclipse.epsilon.concordance.reporter.metamodel.MetamodelChangeReporter.<init>(MetamodelChangeReporter.java:25)
	at org.eclipse.epsilon.concordance.dt.ConcordancePlugin.<init>(ConcordancePlugin.java:28)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
Re: org.eclipse.epsilon.emc.emf.virtual problem [message #1105031 is a reply to message #1105007] Mon, 09 September 2013 04:50 Go to previous messageGo to next message
Thanks for reporting this. I've reproduced this and will investigate. In my setup the error appears in the error log but it doesn't seem to have any impact on the GMF editor generation process. Could you please let me know if it appears to be causing any other side-effects in your setup?
Dimitris
Re: org.eclipse.epsilon.emc.emf.virtual problem [message #1105077 is a reply to message #1105031] Mon, 09 September 2013 06:30 Go to previous messageGo to next message
I've fixed this locally and I'll be pushing out an updated interim version shortly. Could you please file a bug report so that we can keep track of this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=epsilon
Dimitris
Re: org.eclipse.epsilon.emc.emf.virtual problem [message #1105086 is a reply to message #1105077] Mon, 09 September 2013 06:45 Go to previous messageGo to next message
I reported as
url: https://bugs.eclipse.org/bugs/show_bug.cgi?id=416828
No no there is no problem on generation as u say its just appears in the error log, console
Now i see your comment ahh sorry u open me a report but do this manually
[Updated on: Mon, 09 September 2013 06:56] by Moderator
Re: org.eclipse.epsilon.emc.emf.virtual problem [message #1105098 is a reply to message #1105086] Mon, 09 September 2013 07:08 Go to previous message
Thanks for doing this. This has been fixed in the latest interim version.
Dimitris
Previous Topic:Java call from EWL
Next Topic:Cant Generate diagram Tools
Current Time: Sat Jul 26 22:30:16 EDT 2025
Powered by FUDForum. Page generated in 0.08863 seconds
