| Copy/Paste problems [message #110224] |
Thu, 08 March 2007 10:00  |
I've got some problems with the default copy/paste behaviour : some
information are lost, like the text in the labels. Is it normal ? should
I defined my own copy/paste behaviour ? How ?
| Re: Copy/Paste problems [message #122236 is a reply to message #121931] |
Fri, 27 April 2007 08:01  |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
Nevermind,
I´ve got it to work. But this solution is a little strange I think. The
editor I´ve created is able to create diagrams from the semantic model
files, which comply to an xsd I´ve created. Now with the UUIDs enabled
diagram creation doesn´t work anymore for semantic model files created
manually without the UUIDs. Any ideas on that issue?
Greetings,
Christian
Seweryn Niemiec schrieb:
> Thu, 19 Apr 2007 15:56:18 +0200, Christian Dänekas:
>> Hello,
>> I´ve tried this approach, but I still can´t get this to work. I inserted
>> the two classes suggested and registered the new Factory class for the
>> notational model file my editor produces in the plugin.xml . I´m using
> You should enable UUIDs for semantic model.
> Best regards,
> Seweryn Niemiec
FUDForum. Page generated in 0.05040 seconds
