Home » Archived » Test and Performance Tools Platform (TPTP) » No more handles [gtk_init_check() failed] when using the IAC on linux
No more handles [gtk_init_check() failed] when using the IAC on linux [message #109796] Wed, 22 August 2007 13:52 Go to next message
I am attempting to use the IAC (Eclipse 3.2.2 + TPTP 4.3.1) to profile
on Linux RH5. However, everytime I launch my application to profile, I
get this ugly error:
osgi> 2007/08/20 21:09:58.175 SEVERE CLPDN0016E: Error starting
RCPApplication com.ibm.rcp.personality.framework.RCPApplication
::class.method=com.ibm.rcp.personality.framework.internal.RC PApplication.run()
::thread=main ::loggername=com.ibm.rcp.personality.framework.internal
org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(SWT.java:3589)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:8 36)
at org.eclipse.swt.widgets.Display.create(Display.java:824)
at org.eclipse.swt.graphics.Device.<init>(Device.java:152)
at org.eclipse.swt.widgets.Display.<init>(Display.java:472)
at org.eclipse.swt.widgets.Display.<init>(Display.java:463)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:452)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at
com.ibm.rcp.personality.framework.internal.RCPApplication.ru n(RCPApplication.java:65)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at java.lang.reflect.AccessibleObject.invokeL(AccessibleObject. java:213)
at java.lang.reflect.Method.invoke(Method.java:278)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
The "No more handles [gtk_init_check() failed]" issue seems fairly
common and a few work-arounds have been posted, but none of them seem to
make this issue go away, anybody know how to get around it?
BTW, these are the work-arounds I attempted:
set JAVA_HIGH_ZIPFDS=500;
set ulimit -n 65535; pass -vmargs -Dosgi.bundlefile.limit=300 to the
eclipse runtime.
Any and all information is greatly appreciated.
Re: No more handles [gtk_init_check() failed] when using the IAC on linux [message #109858 is a reply to message #109796] Thu, 23 August 2007 06:37 Go to previous messageGo to next message
Hi Rodrigo,
Unrelated to your application, we sometimes see the same symptom when
launching the SWT Manual Test View. See the following explanation and
work-around:
http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_4_0.html#4_CTI_4
Paul
"Rodrigo Pastrana" <rpastran@us.ibm.com> wrote in message
news:faht7b$uv$1@build.eclipse.org...
>I am attempting to use the IAC (Eclipse 3.2.2 + TPTP 4.3.1) to profile on
>Linux RH5. However, everytime I launch my application to profile, I get
>this ugly error:
> at
> at
> at
> at
> at
> at
> The "No more handles [gtk_init_check() failed]" issue seems fairly common
> and a few work-arounds have been posted, but none of them seem to make
> eclipse runtime.
Re: No more handles [gtk_init_check() failed] when using the IAC on linux [message #110326 is a reply to message #109858] Mon, 27 August 2007 09:07 Go to previous messageGo to next message
Hi Paul, I attempted the workaround, but found no new success.
This "No more handles [gtk_init_check() failed]" issue doesn't come up
when trying to connect to the Xserver. It actually occurs when I attempt
to start profiling. I tried bumping up the file descriptor limit by
using the ulimit -n command. Is that what you mean by "Increase the file
descriptor limit."?
I've also tried setting the JAVA_HIGH_ZIPFDS flag to 500, with no luck.
Anybody else seeing this issue?
Paul Slauenwhite wrote:
> Hi Rodrigo,
> work-around:
> Paul
>> this ugly error:
>> at
>> at
>> at
>> at
>> at
>> at
>> eclipse runtime.
Re: No more handles [gtk_init_check() failed] when using the IAC on linux [message #110730 is a reply to message #110326] Thu, 30 August 2007 07:24 Go to previous message
Hi Rodrigo,
Yes, I meant increasing the file descriptor limit by using the ulimit -n
command.
I would try using the Agent Controller and if the problem persists, open
a defect.
Paul
news:fauido$is6$1@build.eclipse.org...
> to start profiling. I tried bumping up the file descriptor limit by using
> descriptor limit."?
>> Hi Rodrigo,
>> work-around:
>> Paul
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> eclipse runtime.
Previous Topic:TPTP for Eclipse C/C++ Project
Next Topic:How to add third-party jars to TPTP/JUnit test?
Current Time: Wed Jul 23 04:50:03 EDT 2025
Powered by FUDForum. Page generated in 0.08613 seconds
