Home » Language IDEs » Java Development Tools (JDT) » EclipseCompiler working standalone but not in plugin
EclipseCompiler working standalone but not in plugin [message #1103075] Fri, 06 September 2013 06:59
In my plugin I want to use org.eclipse.jdt.internal.compiler.tool.EclipseCompiler to compile code in-memory. I want to reuse code which I have successfully tested in a standalone java project. The code is more or less copied from here: http://blog.nobel-joergensen.com/2008/07/16/using-eclipse-compiler-to-create-dynamic-java-objects-2/
While this works well for a standalone project, it doesn't work inside my plugin. The code provides its own implementation of ClassLoader which performs lookup in a hashtable. However this custom classloader's findClass() method is never called. In the standalone version it is called.
There is this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=188796 but I cannot confirm if I'm affected by it since it's only in the plugin context where it's not working.
Is there anything special to be done when running this inside a plugin?
Previous Topic:Installing JDT plugins offline into Eclipse CDT
Next Topic:null for integral types ?
Current Time: Sun Jul 20 22:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.06171 seconds
