Home » Modeling » TMF (Xtext) » What's necessary for using uml2 within xtext plugin?
What's necessary for using uml2 within xtext plugin? [message #1102361] Thu, 05 September 2013 13:32 Go to next message
I register the uml stuff within the generator with the following code:
val resourceSet = new ResourceSetImpl
resourceSet.getPackageRegistry().put(UMLPackage::eNS_URI, UMLPackage::eINSTANCE)
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource::FILE_EXTENSION, UMLResource.Factory::INSTANCE)
val uriMap = resourceSet.getURIConverter().getURIMap()
val url = getClass().getResource("../libs/org.eclipse.uml2.uml.resources_4.1.0.v20130610-0712.jar").toString
val uri = URI::createURI("jar:"+url+"!/")
uriMap.put(URI::createURI(UMLResource::LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""))
uriMap.put(URI::createURI(UMLResource::METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""))
uriMap.put(URI::createURI(UMLResource::PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""))
The libs are stored in the neighbor package "libs" and added on the build path.
Concerning the plugin I also add them to the plug-in classpath.
It works like a charm when I test the generator with a junit test, but it fails when I run the project as eclipse application. I get the following errors:
!ENTRY org.eclipse.emf.ecore 2 0 2013-09-05 19:13:37.629
!MESSAGE org.eclipse.uml2.uml.internal.impl.UMLFactoryImpl cannot be cast to org.eclipse.uml2.uml.UMLFactory
!STACK 0
java.lang.ClassCastException: org.eclipse.uml2.uml.internal.impl.UMLFactoryImpl cannot be cast to org.eclipse.uml2.uml.UMLFactory
at org.eclipse.uml2.uml.internal.impl.UMLFactoryImpl.init(UMLFactoryImpl.java:250)
at org.eclipse.uml2.uml.UMLFactory.<clinit>(UMLFactory.java:36)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.<init>(UMLPackageImpl.java:1865)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1894)
at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:82)
at org.xtext.example.mydsl.generator.MyDslGenerator.doGenerate(MyDslGenerator.java:30)
at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:299)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:229)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:186)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:162)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
!ENTRY org.eclipse.emf.ecore 2 0 2013-09-05 19:13:37.637
!MESSAGE org.eclipse.uml2.types.internal.impl.TypesFactoryImpl cannot be cast to org.eclipse.uml2.types.TypesFactory
!STACK 0
java.lang.ClassCastException: org.eclipse.uml2.types.internal.impl.TypesFactoryImpl cannot be cast to org.eclipse.uml2.types.TypesFactory
at org.eclipse.uml2.types.internal.impl.TypesFactoryImpl.init(TypesFactoryImpl.java:41)
at org.eclipse.uml2.types.TypesFactory.<clinit>(TypesFactory.java:34)
at org.eclipse.uml2.types.internal.impl.TypesPackageImpl.<init>(TypesPackageImpl.java:81)
at org.eclipse.uml2.types.internal.impl.TypesPackageImpl.init(TypesPackageImpl.java:112)
at org.eclipse.uml2.types.TypesPackage.<clinit>(TypesPackage.java:66)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1900)
I uploaded an example project with the same errors to dropbox, maybe it helps for understanding the problem: https://dl.dropboxusercontent.com/u/19175437/problem.zip
Within the generator you can find the registration/pathmap code. When you run an eclipse application, make a new file with the extension "mydsl". Add some code, save it and the errors should occur in the console.
Thanks in advance for any help! These errors are driving me crazy...
Re: What's necessary for using uml2 within xtext plugin? [message #1103301 is a reply to message #1102361] Fri, 06 September 2013 11:41 Go to previous messageGo to next message
Hmmm
can you please elaborate what you actually try todo.
why do you repackage the uml plugin?
Re: What's necessary for using uml2 within xtext plugin? [message #1104024 is a reply to message #1103301] Sat, 07 September 2013 14:57 Go to previous messageGo to next message
Well, I would also like to use my xtext language inside a standalone application, that's why I thought I should copy the uml2 libs...
So there is a better way of doing it?
Thanks!
Re: What's necessary for using uml2 within xtext plugin? [message #1104064 is a reply to message #1104024] Sat, 07 September 2013 16:29 Go to previous messageGo to next message
This all seems very strange.
Surely you should be using UM2Ecore to provide *.ecore models that Xtext
works with happily.
I may be mistaken but I doubt that Xtext has any support for UML and I
doubt that there any plans to support the subtleties of associations,
profiles and redefinitions.
If using UML standalone you absolutely must use UMLResourcesUtil.init()
and copying libraries is likely to cause chaos.
Ed Willink
> Thanks!
Re: What's necessary for using uml2 within xtext plugin? [message #1104389 is a reply to message #1104064] Sun, 08 September 2013 04:58 Go to previous messageGo to next message
Ed Willink wrote on Sat, 07 September 2013 16:29
works with happily.
I just want to generate uml models Wink
Thanks, I will try this out!
Re: What's necessary for using uml2 within xtext plugin? [message #1108152 is a reply to message #1104389] Fri, 13 September 2013 08:14 Go to previous messageGo to next message
I now use UMLResourcesUtil.init() and set the uml2 libs by adding them to the required plug-ins inside the "Dependencies" tab of MANIFEST.MF. I also don't use my lib copies...
But from the moment I add the uml2 plugins, a dsl plugin (i.e. xtext example project) stops working inside an eclipse application...
So what are the steps for adding uml2 libs and using them to generate uml2 models inside the generator?
Thanks!
Re: What's necessary for using uml2 within xtext plugin? [message #1114329 is a reply to message #1108152] Sun, 22 September 2013 11:15 Go to previous message
Ok, I made a silly mistake... I added all uml libs, but when I just add org.eclipse.uml2.uml and org.eclipse.uml2.uml.resources to the dependencies it works fine Smile
However profiles don't work, when I test the generator with junit testcases...
Previous Topic:Import a xtext file into EMF
Next Topic:Two similar rules, but with different cross-references
Current Time: Sun Jul 20 21:29:08 EDT 2025
Powered by FUDForum. Page generated in 0.51959 seconds
