Eclipselink REST 404 responce code [message #1099805] |
Mon, 02 September 2013 04:26  |
I have setup the Eclipse REST AIP environmant.
When i invoke the service from the client i get 404 as response code.
http request is going to the server, somthing is going wrong and return 404 along with the file not found exception.
Can anyone help in solving this issue.
Thanks in advance.
Re: Eclipselink REST 404 responce code [message #1102298 is a reply to message #1099805] |
Thu, 05 September 2013 12:03  |
I am afraid, it is difficult to help without the following information:
- When you say eclipse REST API, do you exactly mean, do you mean JPA-RS or did you implementing something like this http://wiki.eclipse.org/EclipseLink/Examples/REST/GettingStarted/RestService?
- If you are using JPA-RS, how did you package your application ? If you used JPA-RS, this example might help : http://wiki.eclipse.org/EclipseLink/Examples/JPARS/Simple
- What version of eclipselink are you using ?
- Which application server did you use to deploy your application ?
- Do you see any exception on server logs ?
- What operation are you invoking, GET, PUT, POST, DELETE on what rest resource ?
FUDForum. Page generated in 0.06544 seconds
