Home » Archived » Jubula » Question on Object Mapping
Question on Object Mapping [message #1100341] Mon, 02 September 2013 22:10 Go to next message
Hey All!
I just started experimenting automating an Eclipse RCP application with Jubula and its been fun! With the help of the test recorder I'm able to navigate through my test cases, but I'm stuck at the stage where I need to validate if my test output is correct.
I have difficulty with one of the tree structures which has a list of check boxes inside a control but Ctrl + Shift + Q gets the entire tree. How do I make a more specific selection?
Apologies if this is too trivial, but I havnt been able to figure out!
Appreciate your time!! Smile
Edit: I was able to navigate through the output of the table!
[Updated on: Tue, 03 September 2013 17:47] by Moderator
Re: Question on Object Mapping [message #1101479 is a reply to message #1100341] Wed, 04 September 2013 10:08 Go to previous messageGo to next message
have you tried using some of the modules included in the unbound_modules_swt? These actions are called ub_str...
Oliver
Re: Question on Object Mapping [message #1101726 is a reply to message #1101479] Wed, 04 September 2013 18:02 Go to previous messageGo to next message
Thanks Oliver. Got it Smile My first project was for concrete toolkits, so I had to create a new project for rcp/swt and I found the swt specific ones Very Happy Silly me!
Re: Question on Object Mapping [message #1101967 is a reply to message #1101726] Thu, 05 September 2013 03:00 Go to previous message
good to hear that your problem is solved Smile
Previous Topic:Regarding jubula recoding problem
Next Topic:Jubula Extension
Current Time: Thu Jul 24 23:09:53 EDT 2025
Powered by FUDForum. Page generated in 0.24178 seconds
