Home » Eclipse Projects » Eclipse Scout » SDK/RT Source - which tag to checkout
SDK/RT Source - which tag to checkout [message #1101577] Wed, 04 September 2013 12:48 Go to next message
I want to start familiarising myself with the RT and SDK source.
I have cloned the following projects from http://git.eclipse.org/c/scout
  • org.eclipse.scout.rt
  • org.ecipse.scout.sdk
I would like to work on the latest stable codeline, which tag should I check out? Should I go for the Kepler Release Candidate, Kepler_RC4?
Also, after checking out the appropriate tag, what other steps are needed to set up a development environment? Checking out Kepler_RC4, and importing the projects results in thousands of errors in the problem view suggesting to me that I need to set up some other dependencies.
Many thanks.
[Updated on: Wed, 04 September 2013 13:03] by Moderator
Re: SDK/RT Source - which tag to checkout [message #1101655 is a reply to message #1101577] Wed, 04 September 2013 15:32 Go to previous messageGo to next message
Check this out:
Contributions for Scout Committers
You need to follow each step of the "Initial Setup". Let us know if something is unclear or if you need more information.
Re: SDK/RT Source - which tag to checkout [message #1101971 is a reply to message #1101655] Thu, 05 September 2013 03:03 Go to previous messageGo to next message
I just review the page, if you do not want to contribute something, you just need:
* 1.6 Getting the Sources
* 1.7 Compiling in Eclipse
For the tags:
* Kepler_RC4 is the Kepler EPP package from June (with Scout 3.9.0)
* In september there will be an update - Kepler SR1 (Scout 3.9.1), the code is on the release/3.9.1 branch, you can already see some tags for the RC releases.
* On the develop branch, we have started the Luna milestones (Scout 3.10.0)
See also the Git Branching Policy for Eclipse Scout
Re: SDK/RT Source - which tag to checkout [message #1102054 is a reply to message #1101971] Thu, 05 September 2013 05:44 Go to previous messageGo to next message
Many thanks Jeremie.
This morning I was still getting lots of build errors. I'll take another look this evening and report back on the exact steps I followed.
Re: SDK/RT Source - which tag to checkout [message #1103459 is a reply to message #1101577] Fri, 06 September 2013 16:26 Go to previous message
I've fixed the build errors by adding external jars for jms, javamail and jaxws.
I've raised a bug to update the wiki: [1]
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=416772
[Updated on: Sat, 07 September 2013 04:45] by Moderator
Previous Topic:TableField in a Form
Next Topic:Scout Context Diagram
Current Time: Sat Jul 26 02:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.47010 seconds
