Home » Language IDEs » Java Development Tools (JDT) » Ant build uses JDK 1.3 instead of 1.4
Ant build uses JDK 1.3 instead of 1.4 [message #110091] Fri, 24 October 2003 09:30 Go to next message
Originally posted by: felix.mayer.comcast.net
I am doing an ant build of my plug-in with the Eclipse-generated build.xml.
I use assertions in some places, which are compiled just fine by the IDE as
long as I set the Java compiler version to 1.4. However, when I run the ant
build it gives me a compilation error for every assertion.
Is there another place where I need to set the JDK?
Re: Ant build uses JDK 1.3 instead of 1.4 [message #110121 is a reply to message #110091] Fri, 24 October 2003 11:10 Go to previous messageGo to next message
The build.xml that is generated by "Create Ant Build file" has the following
properties defined:
<property name="javacSource" value="1.3"/>
<property name="javacTarget" value="1.1"/>
You should modify these to be 1.4 and 1.2 respectively (either by editing
the file or by using arguments: -DjavacSource=1.4...etc)
HTH
Darins
"Felix Mayer" <felix.mayer@comcast.net> wrote in message
news:bnb9jv$kms$1@eclipse.org...
build.xml.
as
ant
Re: Ant build uses JDK 1.3 instead of 1.4 [message #110152 is a reply to message #110121] Fri, 24 October 2003 11:17 Go to previous messageGo to next message
And to better set this for all future generated buildfiles...see
Window>Preferences>Plug-In Development>Build Option
HTH
Darins
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bnbfbt$r1e$1@eclipse.org...
following
> properties defined:
> HTH
> Darins
> build.xml.
> as
> ant
Re: Ant build uses JDK 1.3 instead of 1.4 [message #110329 is a reply to message #110152] Fri, 24 October 2003 16:49 Go to previous messageGo to next message
Are you talking about Eclipse 3.0? I am using 2.1.1.
In build.xml there are no such properties, and adding them doesn't change
anything.
Also the Preferences dialog doesn't have any Build Option.
Should I move to Eclipse 3.0?
news:bnbfot$rgi$1@eclipse.org...
> HTH
> Darins
> following
> > properties defined:
editing
> > HTH
> > Darins
> > build.xml.
IDE
> > as
the
> > ant
Re: Ant build uses JDK 1.3 instead of 1.4 [message #110354 is a reply to message #110329] Fri, 24 October 2003 17:58 Go to previous message
If you don't state the build that you are using I assume 3.0 :-)
If you move to 3.0 you can follow the instructions I gave.
Darins
news:bnc3bc$eh0$1@eclipse.org...
> anything.
> > HTH
> > Darins
> > following
> > > properties defined:
> editing
> > > HTH
> > > Darins
> > > build.xml.
> IDE
> > > as
> the
> > > ant
Previous Topic:[ANN] SWT Designer FormLayout Preview Pics
Next Topic:Configure Web App
Current Time: Tue Jul 22 02:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.05854 seconds
