Home » Eclipse Projects » Eclipse Platform » customizing conext menu
customizing conext menu [message #1078247] Fri, 02 August 2013 14:50 Go to next message
Hi everyone,
hope that this is the right forum for my Question.
I'm currently developing a EMF/GMF Editor which opens the following context menu while right clicking on elements:
index.php/fa/15818/0/
I would like to customize this by removing stuff like Wizard, Run as, Debug as and so on..This menu entries seams to appear in every explorer view.. Is there a way to remove it for the editor?
Phil
Re: customizing conext menu [message #1088761 is a reply to message #1078247] Sat, 17 August 2013 12:14 Go to previous messageGo to next message
No ideas or wrong forum?
Re: customizing conext menu [message #1088770 is a reply to message #1088761] Sat, 17 August 2013 12:33 Go to previous messageGo to next message
Phil,
It's better to ask on a more specific forum such as eclipse.tools.emf or
eclipse.modeling.gmf. Sorry I overlooked your post....
The entries on on the menu because of the behavior in the generated
XyzActionBarContributor (where Xyz depends on your GenPackage's Prefix
property. You'll find the lofic in the generated void
selectionChangedGen(SelectionChangedEvent event) method...
Re: customizing conext menu [message #1089241 is a reply to message #1088770] Sun, 18 August 2013 07:38 Go to previous messageGo to next message
Hi Ed,
I already asked in the EMF Forum (http://www.eclipse.org/forums/index.php/m/1071096/#msg_1071096), but there you couldn't helped me so I thought this would be a good place to ask Wink
Unfortunately I couldn't find the method you mentioned in my generated actionbarcontributor class. As I mentioned in another post, org.eclipse.emf.edit.ui.action.EditingDomainActionBarContributor.menuAboutToShow(IMenuManager menuManager) seems to be the place where additions (isn't it the stuff like Wizard etc.?) is added. Is it possible to alter this?
Phil
Re: customizing conext menu [message #1091957 is a reply to message #1089241] Thu, 22 August 2013 02:27 Go to previous messageGo to next message
Phil,
All generated editors generate a class that extends
EditingDomainActionBarContibutor that implements
ISelectionChangedListener and implement that method, so you must be able
to find it. And of course you can override any methods you like.
On 18/08/2013 1:38 PM, Phil H wrote:
> Hi Ed,
> to ask ;)
> Cheers,
> Phil
Re: customizing conext menu [message #1094395 is a reply to message #1091957] Sun, 25 August 2013 12:39 Go to previous messageGo to next message
Hi Ed,
so you mean this method: public void selectionChanged(SelectionChangedEvent event) ? I had a look at this method, but couldn't find any hint how to remove Wizard etc.
As the doc metnioned it seems only be responsible for the New Child/Sibling menu:
"...by querying for the children and siblings that can be added to the selected object and updating the menus accordingly."
Cheers
Re: customizing conext menu [message #1100120 is a reply to message #1094395] Mon, 02 September 2013 14:04 Go to previous messageGo to next message
Any further suggestions on this?
Re: customizing conext menu [message #1100477 is a reply to message #1100120] Tue, 03 September 2013 02:53 Go to previous messageGo to next message
Phil,
There are all kinds of example in the existing code. JFace supports
things like object contributions, so that also a possible approach.
Re: customizing conext menu [message #1100720 is a reply to message #1100477] Tue, 03 September 2013 09:51 Go to previous messageGo to next message
What kind of examples do you mean? I was able to figure out how to remove some entries, but there are still entries like "run as", "debug as", "Team" and so on (see attached image).
I thought maybe commeting out "getSite().registerContextMenu(contextMenu, new UnwrappingSelectionProvider(viewer));" in createContextMenuFor(StructuredViewer viewer) would do the trick, but it hasn't changed anything.
I also checked my plugin dependencies, but couldn't find anything which could contribute this menu entries.
I don't really understand how your Jface approach should work. How can object contribution remove menu entries from ymmeditor?
  • Attachment: menus.png
    (Size: 8.50KB, Downloaded 194 times)
Re: customizing conext menu [message #1100850 is a reply to message #1100720] Tue, 03 September 2013 13:43 Go to previous messageGo to next message
Phil,
Are you still trying to remove things or to add things? Maybe someone
else can explain how to remove things; I've not tried to do that... If
you look in the plugin.xml for org.eclipse.emf.ecore.editor, you'll see
how it contributes actions that appear in every contact menu, e.g., this
contribution for creating a dynamic instance form an EClass.
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="org.eclipse.emf.ecore.editor.CreateDynamicInstance"
objectClass="org.eclipse.emf.ecore.EClass">
<action
id="org.eclipse.emf.ecore.editor.CreateDynamicInstanceAction"
label="%_UI_CreateDynamicInstance_menu_item"
menubarPath="additions"
class="org.eclipse.emf.ecore.action.CreateDynamicInstanceAction"
enablesFor="1"/>
</objectContribution>
</extension>
Re: customizing conext menu [message #1102080 is a reply to message #1100850] Thu, 05 September 2013 06:30 Go to previous messageGo to next message
I want to remove it! In the GMF Editor this menu entries don't appear, so there must be added somewhere in the EMF code..But it's hard to track where so I thing it's not possible to remove them..
Re: customizing conext menu [message #1102095 is a reply to message #1102080] Thu, 05 September 2013 06:54 Go to previous messageGo to next message
Phil,
They're not contributed directly by EMF code, but the generated editor,
in the createContextMenu method, calls
org.eclipse.ui.IWorkbenchPartSite.registerContextMenu(MenuManager,
ISelectionProvider) so that "registered contributions" appear in the
context menu.
Re: customizing conext menu [message #1102194 is a reply to message #1102095] Thu, 05 September 2013 09:48 Go to previous messageGo to next message
Hi Ed,
as mentioned before, commenting out getSite().registerContextMenu(contextMenu, new UnwrappingSelectionProvider(viewer)) in createContextMenuFor(StructuredViewer viewer) doesn't change anything. Is this normal or should this normally remove the menu entries?
Re: customizing conext menu [message #1102204 is a reply to message #1102194] Thu, 05 September 2013 10:03 Go to previous messageGo to next message
Phil,
I just tested your assertion and it appears to be false. In any case,
EMF does not add those entries; they must come from registrations...
On 05/09/2013 3:48 PM, Phil H wrote:
> Hi Ed,
Re: customizing conext menu [message #1102234 is a reply to message #1102204] Thu, 05 September 2013 10:52 Go to previous messageGo to next message
Hi Ed,
what do you mean with false? My assertion or what you mentioned before?
So with registrations you mean the extensions defined in the plugin.xml of the generated editor project?
Re: customizing conext menu [message #1102261 is a reply to message #1102234] Thu, 05 September 2013 11:18 Go to previous messageGo to next message
Phil,
Your assertion is false: commenting out that call results, for me, in a
context menu with only the things directly contributed by the generated
code (and the base classes the generate code extends).
By registrations I mean other plugins (i.e., neither EMF and nor your
generated plugins) that contribute menu items that target the context
menus throughout Eclipse.
On 05/09/2013 4:52 PM, Phil H wrote:
> Hi Ed,
Re: customizing conext menu [message #1102293 is a reply to message #1078247] Thu, 05 September 2013 11:57 Go to previous messageGo to next message
Hmm, that is really odd..So you don't have any menu entries like Wizards, Run As, Debus As, Team and son anymore?
I can't remember that I've added additional plugins..At all I give up with this..
Re: customizing conext menu [message #1102307 is a reply to message #1102293] Thu, 05 September 2013 12:11 Go to previous messageGo to next message
Phi,
Comments below.
No, those are contributed by other things in the platform and that call
registers the context menu to receive those contributions...
> with this..
When you launch, any plugin included in the launch configuration can
register extension in their plugin.xmls that contribute to these menu
items; by default that's all your bundles in the workspace and all the
bundles in your target platform, i.e., the debugger framework, the team
framework, and so on.
Re: customizing conext menu [message #1103034 is a reply to message #1102307] Fri, 06 September 2013 06:08 Go to previous messageGo to next message
Hi Ed,
you're right, I just found out that there is another class which calling this method. Commeting out this removed all the contributed stuff like "Wizards" etc., but unfortunately also the menuitem which I contributed in the plugin.xml isn't shown anymore.
Just calling getSite().registerContextMenu("myCommandId", contextMenu, new UnwrappingSelectionProvider(viewer)); hasn't worked.
So I thought about filtering out the unwanted contributions with this code:
protected void createContextMenuFor(StructuredViewer viewer) {
	MenuManager contextMenu = new MenuManager("#PopUp") {
		public IContributionItem[] getItems() {
			IContributionItem[] items = super.getItems();
			List<IContributionItem> filteredItems = new ArrayList<IContributionItem>();
			for (IContributionItem item : items) {
				if (item != null && item.getId() != null && ((item.getId().startsWith("org.itea2"))))
				      filteredItems.add(item);
				items = new IContributionItem[filteredItems.size()];
				return filteredItems.toArray(items);
	contextMenu.add(new Separator("additions"));
	contextMenu.setRemoveAllWhenShown(true);
	contextMenu.addMenuListener(this);
	Menu menu = contextMenu.createContextMenu(viewer.getControl());
	viewer.getControl().setMenu(menu);
	int dndOperations = DND.DROP_COPY | DND.DROP_MOVE | DND.DROP_LINK;
	Transfer[] transfers = new Transfer[] { LocalTransfer.getInstance() };
	viewer.addDragSupport(dndOperations, transfers, new ViewerDragAdapter(viewer));
	viewer.addDropSupport(dndOperations, transfers, new EditingDomainViewerDropAdapter(getEditingDomain(), viewer));
This works fine for my menuitem, but it turned out that using this filter (it doesn't matter which string is used in item.getId().startsWith("org.itea2")) results in a context menu without the EMF menu items like "New Child", "undo" etc.
Is there any workaround for this?
[Updated on: Fri, 06 September 2013 06:14] by Moderator
Re: customizing conext menu [message #1103691 is a reply to message #1103034] Sat, 07 September 2013 01:40 Go to previous messageGo to next message
Phil,
Comment below.
On 06/09/2013 12:08 PM, Phil H wrote:
> Hi Ed,
Yes, that's to ge expected.
No, the ID you use is important.
> code:
> @Override
> filter (it doesn't matter which sring is used in
It looks like your filter filters out pretty much everything. Are you
actually using a debugger to observe what your filter is doing?
Re: customizing conext menu [message #1104080 is a reply to message #1103691] Sat, 07 September 2013 16:57 Go to previous message
It seems that the EMF menu items have no ID, so the following has done the trick:
if ((item != null) && ((item.getId() == null) || (item.getId().startsWith("org.itea2")))) {
Previous Topic:Error Log - Problem occurred when invoking org.eclipse.ui.navigator
Next Topic:Eclipse Console Caret Position
Current Time: Thu Jul 24 17:59:23 EDT 2025
Powered by FUDForum. Page generated in 0.08365 seconds
