Home » Eclipse Projects » Eclipse Scout » Outline Table Page with search form - prevent initial table data load(Outline Table Page with search form - prevent initial table data load)
Outline Table Page with search form - prevent initial table data load [message #1100219] Mon, 02 September 2013 17:21 Go to next message
Based on the example code of the MINICRM it looks like if one has an outline table page with a search form this table is always filled when opening the screen. Filters to limit the amount of data are applied afterwards.
Is there a possibility that when opening the screen, no query is executed, but only when pressing "search" the query is executed ?
I could trick it a little bit with the "where" statement that could resolve to false instead of a 1 = 1, but it is a roundtrip to the database i would like to prevent.
Kind regards
Tore
Re: Outline Table Page with search form - prevent initial table data load [message #1100422 is a reply to message #1100219] Tue, 03 September 2013 01:20 Go to previous messageGo to next message
I have just written this: Table page > Force the user to use the search form
Let me know if you need more (or something else).
Re: Outline Table Page with search form - prevent initial table data load [message #1100894 is a reply to message #1100422] Tue, 03 September 2013 15:08 Go to previous message
Perfect
Exactly what I needed.
Previous Topic:scout kepler SMTP service bug?
Next Topic:Specific differences between the different "Types of Application"?
Current Time: Fri Jul 25 19:51:59 EDT 2025
Powered by FUDForum. Page generated in 0.03077 seconds
