Home » Modeling » Graphiti » how to get file path created by wizard after the wizard execute
how to get file path created by wizard after the wizard execute [message #1099632] Sun, 01 September 2013 22:03 Go to next message
hi gays,i know that this question is not suitable for this part. however, I do not know the right place for it.
i create a diagram file by another plugin's wizard,after the wizard execute,i need know the diagram file path. besides,since i get the wizard by its id,i can not change the code of that wizard. i will appreciate your help
Re: how to get file path created by wizard after the wizard execute [message #1099756 is a reply to message #1099632] Mon, 02 September 2013 03:00 Go to previous messageGo to next message
Not sur if its help, but have you checked the Drill-down tutorial ? The
snippet provided shows how to get all the diagrams inside the workspace.
You might check diff on diagram collection before and after executing
your wizard.
Nicolas H
Re: how to get file path created by wizard after the wizard execute [message #1100346 is a reply to message #1099756] Mon, 02 September 2013 22:17 Go to previous messageGo to next message
Hi Nicolas,
Thank you for your clue,but I don't know what you mean the drill-down tutorial.Is it the tutorial in eclipse graphiti help?
By the way,I solve the problem by not a very elegant method.i forked a new plugin from the older one and changed the wizard. now I can get the file path.
Re: how to get file path created by wizard after the wizard execute [message #1100496 is a reply to message #1100346] Tue, 03 September 2013 03:25 Go to previous messageGo to next message
Hi Xiao,
Le 03/09/13 04:17, xiao yu zhou a écrit :
> Hi Nicolas,
> file path.
Above, the URL for the Drill-down tutorial on the Eclipse Graphiti Help.
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fresources%2Fdocu%2Fgfw%2Fdrill-down.htm&cp=25_1_3_11
Nicolas H
Re: how to get file path created by wizard after the wizard execute [message #1101412 is a reply to message #1099632] Wed, 04 September 2013 08:27 Go to previous message
The ability to get a file for an EMF resource (in which the diagram is
stored) depends on the type and location of the resource. It must
a) be represented as a file
b) exist in the Eclipse workspace
The internal Graphiti class
org.eclipse.graphiti.ui.internal.services.impl.EmfService has several
methods getFile that might be interesting to solve this.
Michael
Previous Topic:graphiti diagram editor xmi persistence encoding
Next Topic:Selection Listener
Current Time: Sun Jul 27 11:33:01 EDT 2025
Powered by FUDForum. Page generated in 0.05903 seconds
