Problems occurred when invoking code from plug-in: "org.eclipse.jface" [message #1099353] |
Sun, 01 September 2013 11:09  |
I have one .ecore file which contained one Eclass with one Name feature. I create diagram file for this ecore file by using GMF. for Name feature, I followed GMF tutorial and create 'feature label mapping' for it and set it. I launch to created diagram file but when i select my class as one object and want to change Name feature, i get this error:
An error has occurred. See error log for more details.
org/eclipse/gmf/runtime/gef/ui/internal/parts/CellEditorEx.
in error log :
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
can every one help me?
Exception stack trace:
java.lang.NoClassDefFoundError: org/eclipse/gmf/runtime/gef/ui/internal/parts/CellEditorEx
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.LabelDirectEditPolicy.getDirectEditCommand(LabelDirectEditPolicy.java:67)
at org.eclipse.gef.editpolicies.DirectEditPolicy.getCommand(DirectEditPolicy.java:59)
at org.eclipse.gef.editparts.AbstractEditPart.getCommand(AbstractEditPart.java:502)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$1(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$1.run(GraphicalEditPart.java:482)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.getCommand(GraphicalEditPart.java:477)
at org.eclipse.gef.tools.DirectEditManager.commit(DirectEditManager.java:144)
at org.eclipse.gmf.tooling.runtime.directedit.DirectEditManagerBase.commit(DirectEditManagerBase.java:304)
at org.eclipse.gef.tools.DirectEditManager$4.applyEditorValue(DirectEditManager.java:298)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:335)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(CellEditor.java:333)
at org.eclipse.jface.viewers.CellEditor.focusLost(CellEditor.java:718)
at org.eclipse.jface.viewers.TextCellEditor$5.focusLost(TextCellEditor.java:186)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:143)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2822)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1921)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:4900)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4562)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2254)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4985)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3114)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3749)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
and more details:
eclipse.buildId=M20110909-1335
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data D:\eclipse64\workspace/../runtime-test -dev file:D:/eclipse64/workspace/.metadata/.plugins/org.eclipse.pde.core/test/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
FUDForum. Page generated in 0.05693 seconds
