BIRT Large Dataset Performance [message #1095908] |
Tue, 27 August 2013 13:54  |
I am using BIRT to dump some data down in reports. It works good upto some size of datasets, and as the dataset grows the performance goes down. I have a dataset with ~30K rows that are handed over to BIRT for grouping and displaying. It just seem to take hours and hours to process this, what can I possibly do to improve this ?
Re: BIRT Large Dataset Performance [message #1111796 is a reply to message #1111243] |
Wed, 18 September 2013 14:58  |
Well, your two tables are made from the same dataSet. If you simply create a query that returns the results you want in the embedded table, you can create a dataSet parameter by using the '?' marker in the query. For example, select * from table where field = ?. Now, if you select the embedded table that is bound to this dataSet and go to the binding tab, you'll see a button for dataset parameter binding. If you select this, you can pass the group value from the outer table to the inner table to limit the inner query results.
FUDForum. Page generated in 0.06368 seconds
