Home » Modeling » M2T (model-to-text transformation) » [XPAND] Xpandfacade with metamodel .ecore
[XPAND] Xpandfacade with metamodel .ecore [message #1093594] Sat, 24 August 2013 06:01 Go to next message
HI ALL ,
I am new with xapnd language , and I am wondering if there is any good documentation about xpnadfacade and how to use it .
I have actually a template written in xpand language to generate code out of .ecore file . all work fine when I run it using the workflow as " run as " after some modification for workflow file to run on .ecore file for sure.
but I want to use the template without workflow from java code . I reached to xpandfacade as the solution but I do not know how to specifiy my .ecore file as it is parameter in my application and the user will choose .ecore file from enry form I offer .
sample of my code
          Shell shell = new Shell(Display.getDefault());
		FileDialog modelDialog = new FileDialog(shell, SWT.OPEN);
		modelDialog.setFilterExtensions(new String[] { "*.ecore" });
		modelDialog.setText("Select Model to transform...");
		String modelSelected = modelDialog.open();
now I have my model as string in modelSelected variable .
after creating xpand context i use
xpandfacade.evaluate(java.lang.String definitionName,
                      java.lang.Object targetObject,
                     java.lang.Object... params)
definitionName : I use the template path separated by ::
but I do not know what is targetObjec, and params . and how I specify my model with this function ?
sorry for my bad english ,hope to see some responses soon .
Re: [XPAND] Xpandfacade with metamodel .ecore [message #1095564 is a reply to message #1093594] Tue, 27 August 2013 04:12 Go to previous messageGo to next message
i am not quite sure what your question is targeting. is it how to i read a ecore model?
targetObject is the Object or List of Object that shall be processed.
params are the parameters that go into the transformation (if you have any ..)
«DEFINE definionName FOR Entity(String a, Boolean b)»«ENDDEFINE»
Re: [XPAND] Xpandfacade with metamodel .ecore [message #1096050 is a reply to message #1095564] Tue, 27 August 2013 18:45 Go to previous messageGo to next message
Thank you christian for response.
what I meant that my model that i am working with is actually the .ecore file which is the metamodel . and this .ecore is choosen by user from system , so the model is not included in my plugin. and I want to implement my template file on this metamodel .ecore file
i have for example this path of the model
c:\mymodels\mymodel.ecore , and I have template that access the element in this model
with this path
Template::mytemplate::main
how I can use xpandfacde class with these file mymodel.ecore and the template ?
thanks again and please be patient with me Smile
[Updated on: Tue, 27 August 2013 18:46] by Moderator
Re: [XPAND] Xpandfacade with metamodel .ecore [message #1096301 is a reply to message #1096050] Wed, 28 August 2013 03:58 Go to previous messageGo to next message
are you asking how to read the model or how to tell xpand to use the specific metamodel?
for the first one you can use std emf facilities - not xpand related.
for the second you can call registerMetamodel on the executioncontext. with a new EmfMetaModel instance onwich you called setMetaModelFile (basically the same as you did in your workflow)
Re: [XPAND] Xpandfacade with metamodel .ecore [message #1098013 is a reply to message #1096301] Fri, 30 August 2013 09:22 Go to previous message
nice , Thank you very much .
Previous Topic:Adding Modelelemets to the Model during Editing
Next Topic:JET2 Editor Source Code
Current Time: Wed Sep 17 03:42:20 EDT 2025
Powered by FUDForum. Page generated in 0.06595 seconds
