Home » Archived » Test and Performance Tools Platform (TPTP) » Missing Constraint: Require-Bundle... for org.eclipse.tptp.platform.profile.server.wst
Missing Constraint: Require-Bundle... for org.eclipse.tptp.platform.profile.server.wst [message #109782] |
Wed, 22 August 2007 13:02  |
TPTP has caused me more problems than anything else in upgrading to Eclipse
3.3.
The latest problem is that when using the Validate button on the Plug-ins
tab for the runtime-workspace, I get the following error on
org.eclipse.tptp.platform.server.wst:
Missing Constraint: Require-Bundle: org.eclipse.jst.server.core;
bundle-version="[1.0.0,2.0.0)"
There is then an entry in the Error Log in the Runtime Workbench to the same
effect. This happens every time I start it.
I have Eclipse 3.3 and have the last updates for TPTP via "Search for
updates of the currently installed features". I have got all of TPTP via
Europa initially and via this means after.
I would think TPTP should have checked for such requirements when installing
the updates. It is somewhat inconvenient to try to find the required
plug-ins manually. It is more easily fixed by just unchecking
org.eclipse.tptp.platform.server.wst as a plug-in on the mentioned tab.
-Ken
Re: Missing Constraint: Require-Bundle... for org.eclipse.tptp.platform.profile.server.wst [message #110798 is a reply to message #109966] |
Thu, 30 August 2007 11:14  |
------=_NextPart_000_0014_01C7EAEE.9C5A0610
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Joel,
Thanks for your reply. I agree that the Update Manager has problems. =
It has been getting better with each version, however. it is one of the =
real advantages of using Eclipse. It does work OK most of the time, and =
my experience is that it is usually owing to a bad configuration of the =
update site when it doesn't.
In any event, I don't want to manage Eclipse plug-ins manually. I =
appologize if that seems uncooperative, but I don't have the time to do =
that. I will uninstall TPTP first. That would be unfortunate as I have =
found it to be an impressive tool. But it is not something I use on a =
daily basis.
I also don't want to install WTP if I can avoid it. I have found it to =
be buggy and it caused me far more problems with 3.2 than TPTP has with =
3.3. I do need to use it, but until I have the time to babysit it more =
thoroughly, I would rather not have it installed. It like, TPTP, is =
interfering with the time I have to spend on things that I do have to do =
on a daily basis.
I also don't want to install everything in sight that might find the =
missing plug-in. That will just cause more problems. I have found KISS =
to be an excellent guiding principle. (I guess that would mean =
uninstalling TPTP ;-)
When providing features on an update site, the developer has the =
obligation to specify the correct dependencies in the feratures. For =
something as complicated as TPTP that may not be easy, but the =
responsibly should be on the developer to do that. I believe that if =
the feature dependencies are specified correctly, then there should be =
no "missing constraints" in the plug-ins. I think the problem should be =
corrected on the update-site end.
I am not currently having trouble with other projects since upgrading to =
3.3.
Thanks again,.
-Ken
<jcayne@ca.ibm.com> wrote in message =
news:fan8nc$8ph$1@build.eclipse.org...
Hi Ken,=20
The jar that is missing is part of the WTP dependency. There are known =
issues with Update Manager not obtaining some bundles during install. I =
would suggest getting the dependecies using the links from our website =
(http://www.eclipse.org/tptp/home/downloads/) and putting them in your =
workbench. In my replication of the problem, I downloaded DTP, EMF, GEF =
and WTP to fix the missing constraint error. You may want to also =
install BIRT. Please follow up with your outcome.=20
Joel
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16481" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Joel,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your reply. I agree =
that the=20
Update Manager has problems. It has been getting better with each =
version,=20
however. it is one of the real advantages of using Eclipse. =
It does=20
work OK most of the time, and my experience is that it is usually owing =
to a bad=20
configuration of the update site when it doesn't.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>In any event, I don't want to manage =
Eclipse=20
plug-ins manually. I appologize if that seems uncooperative, but I =
don't=20
have the time to do that. I will uninstall TPTP first. That =
would be=20
unfortunate as I have found it to be an impressive tool. But it is =
not=20
something I use on a daily basis.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I also don't want to install WTP if I =
can avoid=20
it. I have found it to be buggy and it caused me far more problems =
with=20
3.2 than TPTP has with 3.3. I do need to use it, but until I have =
the time=20
to babysit it more thoroughly, I would rather not have it =
installed. =20
It like, TPTP, is interfering with the time I have to spend on things =
that I do=20
have to do on a daily basis.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I also don't want to install everything =
in sight=20
that might find the missing plug-in. That will just cause more=20
problems. I have found KISS to be an excellent guiding =
principle. (I=20
guess that would mean uninstalling TPTP ;-)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>When providing features on an update =
site, the=20
developer has the obligation to specify the correct dependencies in the=20
feratures. For something as complicated as TPTP that may not be =
easy, but=20
the responsibly should be on the developer to do that. I believe =
that if=20
no=20
"missing constraints" in the plug-ins. I think the problem should =
be=20
corrected on the update-site end.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am not currently having trouble with =
other=20
projects since upgrading to 3.3.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks again,.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =
-Ken</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV><<A =
href=3D"mailto:jcayne@ca.ibm.com">jcayne@ca.ibm.com</A>> wrote in=20
message <A=20
href=3D"news:fan8nc$8ph$1@build.eclipse.org">news:fan8nc$8ph$1@build.ecli=
pse.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi Ken,</FONT> <BR><BR><FONT =
face=3Dsans-serif size=3D2>The=20
issues with=20
Update Manager not obtaining some bundles during install. I would =
suggest=20
getting the dependecies using the links from our website=20
workbench. In my replication of the problem, I downloaded DTP, EMF, =
GEF and=20
WTP to fix the missing constraint error. You may want to also install =
BIRT.=20
Please follow up with your outcome.</FONT> <BR><BR><FONT =
face=3Dsans-serif=20
size=3D2>Joel</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0014_01C7EAEE.9C5A0610--
Current Time: Sun Jul 27 10:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
