Home » Eclipse Projects » Eclipse 4 » LoginDialog in LifeCycleManager
LoginDialog in LifeCycleManager [message #1096368] Wed, 28 August 2013 05:40 Go to next message
Hello all,
I am writing an E4 application from scratch and I am struggling to get the following working:
Before the application's main window is shown, I want to display a login dialog. When successful, the main window is displayed, otherwise the system exits. I have implemented this using a life cycle manager as described here:
http://www.vogella.com/articles/Eclipse4LifeCycle/article.html
public class LifeCycleManager {
	@PostContextCreate
	public void postContextCreate() {
		final Shell shell = new Shell(SWT.TOOL | SWT.NO_TRIM);
		LoginDialog dialog = new LoginDialog(shell);
		if (dialog.open() != Window.OK) {
			// close the application
			System.exit(-1);
This works and my LoginDialog is shown. However, I would like my application to remember the values in this dialog. In Eclipse 3 I achieved this using IDialogSettings, but it looks like I cannot use this in E4.
Any suggestions how to implements this in E4?
Thanks in advance,
Arjan
Re: LoginDialog in LifeCycleManager [message #1097339 is a reply to message #1096368] Thu, 29 August 2013 11:20 Go to previous messageGo to next message
You can either persist them in the MApplication's 'persistedData' map (If you want to fill in the dialog on the next start...) or in its 'transientData' field if not. These are both maps with String 'keys', how you choose to save the info is up to you...
You can @Inject the MApplication...
Re: LoginDialog in LifeCycleManager [message #1097487 is a reply to message #1097339] Thu, 29 August 2013 16:03 Go to previous messageGo to next message
Hello Eric,
Thanks for your help!
I tried injecting the MApplication into the LifeCycleManager class:
	@Inject
	MApplication application;
	@PostContextCreate
	public void postContextCreate(IEclipseContext context) {
			System.exit(-1);
However, this results in an error:
org.eclipse.e4.core.di.InjectionException: Unable to process "LifeCycleManager.application": no actual value was found for the argument "MApplication".
Next, I tried injecting it in my LoginDialog class, but all I get is a null value.
public class LoginDialog extends TitleAreaDialog {
	// Widgets
	private Text textUsername;
	private Text textPassword;
	@Inject
	public LoginDialog(Shell parent) {
		super(parent);
	protected Control createContents(Composite parent) {
		Control contents = super.createContents(parent);
		setTitle("Credentials");
		setMessage("Please provide the credentials.");
		return contents;
	protected Control createDialogArea(Composite parent) {
		Composite area = (Composite) super.createDialogArea(parent);
		System.out.println(application);
		Composite container = new Composite(area, SWT.NULL);
		container.setLayout(new GridLayout(2, false));
		container.setLayoutData(new GridData(GridData.FILL_BOTH));
		new Label(container, SWT.NULL).setText("Username");
		textUsername = new Text(container, SWT.BORDER);
		textUsername.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
		new Label(container, SWT.NULL).setText("Password");
		textPassword = new Text(container, SWT.PASSWORD | SWT.BORDER);
		textPassword.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
		return area;
	protected Point getInitialSize() {
		return new Point(500, 300);
Any idea what I am missing?
Arjan
[Updated on: Thu, 29 August 2013 16:04] by Moderator
Re: LoginDialog in LifeCycleManager [message #1097523 is a reply to message #1097487] Thu, 29 August 2013 17:10 Go to previous messageGo to next message
Nothing - the model has not been loaded at this point you need to use
another point in time e.g. @ProcessAddons
Tom
On 29.08.13 22:03, Arjan Huijzer wrote:
> Hello Eric,
> @Inject
> @PostContextCreate
> System.exit(-1);
> null value.
> // Widgets
> @Inject
> public CredentialsDialog(Shell parent) {
> super(parent);
> @Override
> return contents;
> @Override
> return area;
> @Override
> Arjan
Re: LoginDialog in LifeCycleManager [message #1097737 is a reply to message #1097523] Fri, 30 August 2013 01:22 Go to previous messageGo to next message
Hello Tom,
Thanks for your help. I am one step closer, but I still have not got it working......
I now use @ProcessAdditions in my LIfeCycleManager. Furthermore, I used ContextInjectionFactory to inject the context into the login dialog.
	@ProcessAdditions
	public void processAdditions(IEclipseContext context) {
		ContextInjectionFactory.inject(dialog, context);
			System.exit(-1);
In the LoginDialog the state is persisted in the following method:
protected void okPressed() {
	application.getPersistedState().put(CREDENTIALS_USERNAME, textUsername.getText());
	super.okPressed();
When I run the application, the state seems to be persisted after I close it. My workbench.xmi file has the following entry:
<persistedState key="credentials.username" value="Arjan"/>
However, when I start the application again, the code to read the persisted state in the login dialog does not seem to work:
String persistedUsername = application.getPersistedState().get(CREDENTIALS_USERNAME);
persistedUsername is NULL Sad
Note: I did remove the clearPersistedState property from the plugin.xml.
Arjan
Re: LoginDialog in LifeCycleManager [message #1098167 is a reply to message #1097737] Fri, 30 August 2013 14:18 Go to previous messageGo to next message
Most likely you launch with -clearPersistedState
Tom
On 30.08.13 07:22, Arjan Huijzer wrote:
> Hello Tom,
> working......
> @ProcessAdditions
> System.exit(-1);
> @Override
> super.okPressed();
> persistedUsername is NULL :(
> Arjan
Re: LoginDialog in LifeCycleManager [message #1098239 is a reply to message #1098167] Fri, 30 August 2013 16:45 Go to previous messageGo to next message
You were right, I launched the application with -clearPersistedState. Once I removed it, all was working as intended Smile
Thanks for the help!!
Arjan
Re: LoginDialog in LifeCycleManager [message #1706133 is a reply to message #1098239] Mon, 24 August 2015 01:12 Go to previous message
But friend I am try to check login validation and false time focus login screen and correct to open application, how and where i'm apply code and i am post my code also....
Login Dialog
import javax.inject.Inject;
import org.eclipse.e4.ui.model.application.MApplication;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
	// Widgets
	public static Text textUsername;
	public static Text textPassword;
	@Inject
//	@Inject
//	EMenuService menuService;
	 * @wbp.parser.constructor
	public LoginDialog() {
		super(null);
	@Inject
	public LoginDialog(Shell parentShell) {
		super(parentShell);
		setTitle("Login");
		setMessage("Please provide credentials");
		return contents;
		checkLoginValidation(textUsername.getText(),textPassword.getText());
		return area;
	private void checkLoginValidation(String text, String text2) {
Lifecycle manager class
package secdemo;
import org.eclipse.e4.core.contexts.ContextInjectionFactory;
import org.eclipse.e4.core.contexts.IEclipseContext;
import org.eclipse.e4.core.services.events.IEventBroker;
import org.eclipse.e4.ui.di.UIEventTopic;
import org.eclipse.e4.ui.workbench.UIEvents;
import org.eclipse.e4.ui.workbench.lifecycle.PostContextCreate;
import org.eclipse.e4.ui.workbench.lifecycle.PreSave;
import org.eclipse.e4.ui.workbench.lifecycle.ProcessAdditions;
import org.eclipse.e4.ui.workbench.lifecycle.ProcessRemovals;
import org.eclipse.equinox.app.IApplicationContext;
import org.eclipse.jface.window.Window;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Monitor;
import org.eclipse.e4.core.di.annotations.Optional;
import org.osgi.service.event.Event;
import org.osgi.service.event.EventHandler;
import login.LoginDialog;
@SuppressWarnings("restriction")
public class Manager {
	@PostContextCreate
	void postContextCreate(IEclipseContext workbenchContext) {
	@PreSave
	void preSave(IEclipseContext workbenchContext) {
	@ProcessAdditions
	void processAdditions(final IEclipseContext workbenchContext, IEventBroker eventBroker) {
		LoginDialog dialog = ContextInjectionFactory.make(LoginDialog.class, workbenchContext);
		if(dialog.open() != Window.OK){
			// close application
			System.exit(-1);
		eventBroker.subscribe(UIEvents.UILifeCycle.APP_STARTUP_COMPLETE, new EventHandler() {
//			@Override
			public void handleEvent(Event event) {
//				if(LoginDialog.textUsername.getText().equals("123") && LoginDialog.textPassword.getText().equals("123") ){
					appStartupComplete(workbenchContext);
		// continue to the initial window
	@ProcessRemovals
	void processRemovals(IEclipseContext workbenchContext) {
	@Optional
	public void applicationStartupComplete(@UIEventTopic(UIEvents.UILifeCycle.APP_STARTUP_COMPLETE) Event event)
	private void appStartupComplete(IEclipseContext workbenchContext) {
		@PostContextCreate
	  void postContextCreate(IApplicationContext appContext, Display display) {
	    final Shell shell = new Shell(SWT.LEFT);
	    // close the static splash screen
	    appContext.applicationRunning();
	    // position the shell
	    setLocation(display, shell);
	      System.exit(-1);
	  private void setLocation(Display display, Shell shell) {
	    Monitor monitor = display.getPrimaryMonitor();
	    Rectangle monitorRect = monitor.getBounds();
	    Rectangle shellRect = shell.getBounds();
	    int x = monitorRect.x + (monitorRect.width - shellRect.width) / 2;
	    int y = monitorRect.y + (monitorRect.height - shellRect.height) / 2;
	    shell.setLocation(x, y);
apply plugin.xml file in lifecycleURI....
Pleas help me friend .....
Previous Topic:Create a common delta pack of an RCP application that runs in all the OS ?
Next Topic:Eclipse 4 RCP with ibm rational Doors Database
Current Time: Sat Jul 26 06:16:43 EDT 2025
Powered by FUDForum. Page generated in 0.05378 seconds
