Home » Eclipse Projects » Remote Application Platform (RAP) » Missing required Bundle, wrong version number?
Missing required Bundle, wrong version number? [message #108854] |
Sat, 11 October 2008 08:52  |
This is very strange, when trying to launch my Eclipse RAP (1.1) app on
Ganymede, I get the following error:
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.runtime;
bundle-version="0.0.0"
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
...trace continues...
Problem is, I have org.eclipse.core.runtime checked off in my Bundles
tab...it's definitely selected, but my version is 3.4.0 instead of
0.0.0...why would it require an invalid version of the runtime bundle?
Re: Missing required Bundle, wrong version number? [message #109186 is a reply to message #108887] |
Tue, 14 October 2008 18:33   |
The bundles I am using are:
2 workspace bundles, com.ibm.icu, javax.servlet,
org.eclipse.core.commands, org.eclipse.core.contenttype,
org.eclipse.core.databinding, org.eclipse.core.expressions,
org.eclipse.core.jobs, org.eclipse.core.runtime, org.eclipse.equinox.app,
org.eclipse.equinox.common, org.eclipse.equinox.http.registry,
org.eclipse.equinox.preferences, org.eclipse.equinox.registry,
org.eclipse.osgi, org.eclipse.osgi.services, org.eclipse.rap.jface,
org.eclipse.rap.jface.databinding, org.eclipse.rap.rwt,
org.eclipse.rap.rwt.q07, org.eclipse.rap.ui, org.eclipse.rap.ui.forms,
org.eclipse.rap.ui.forms.views, org.eclipse.rap.ui.workbench
Below is the full stack trace:
!SESSION 2008-10-11 08:33:35.830
eclipse.buildId=unknown
java.version=1.5.0_10
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -dev
file:~/workspace/.metadata/.plugins/org.eclipse.pde.core/RAP
Application/dev.properties -os linux -ws gtk -arch x86_64
!ENTRY com.vertica.viztool 4 0 2008-10-11 08:33:37.009
!MESSAGE
!STACK 0
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
!ENTRY org.eclipse.osgi 4 0 2008-10-11 08:33:37.021
!MESSAGE Bundle initial@reference:file:../../../../workspace/viztoolRAP/
was not resolved.
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.032
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.032
was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.032
!MESSAGE Missing required bundle org.eclipse.rap.ui.views_1.1.1.
!MESSAGE Missing required bundle org.eclipse.core.runtime_0.0.0.
!MESSAGE Missing required bundle org.eclipse.rap.ui.forms_1.1.1.
!MESSAGE Missing required bundle org.eclipse.rap.ui_1.1.1.
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.033
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.033
[5] was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.034
!ENTRY org.eclipse.osgi 4 0 2008-10-11 08:33:37.039
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.041
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.041
was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.041
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.042
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.043
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.043
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.043
Stefan Roeck wrote:
> Hi Adam,
> Have you tried starting the bundle "org.eclipse.core.runtime" manually
> at OSGi console?
> start <bundle_id>
> Maybe there's another error... What does your bundle list (ss) look like?
> Regards,
> Stefan.
>> at
Re: Missing required Bundle, wrong version number? [message #109320 is a reply to message #109186] |
Thu, 16 October 2008 04:05   |
Originally posted by: rherrmann.innoopract.com
the OSGi messages suggest that com.vertica.viztool requires
....core.runtime in a version that is not available (0.0.0)
Could you have a look at the Require_bundle clause in your
MANIFEST.MF and see if there is a version constraint?
HTH
Rüdiger
> org.eclipse.equinox.app, org.eclipse.equinox.common,
> org.eclipse.equinox.http.registry, org.eclipse.equinox.preferences,
> org.eclipse.equinox.registry, org.eclipse.osgi,
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> was not resolved.
> was not resolved.
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> was not resolved.
> Stefan Roeck wrote:
>> Hi Adam,
>> at OSGi console?
>> start <bundle_id>
>> Regards,
>> Stefan.
>>> on Ganymede, I get the following error:
>>> at
Re: Missing required Bundle, wrong version number? [message #109704 is a reply to message #109518] |
Fri, 17 October 2008 12:49   |
I don't really remember -- I did a combination of it both manually (Run
Configuration...) and automatically through the plugin.xml file.
I mean basically I had an RCP project, I changed the target platform over
to RAP when I installed it. I corrected all of the compile errors, then
tried to run it and it failed. Then I realized I had old bundles so I went
into the Run Configurations and made sure to click "include required
bundles" to update the Run. Still failed.
Then I went back to the <projectname>.product and plugin.xml files and
updated to make sure all of the dependencies were updated (which they
weren't, so I deleted the RCP only ones and clicked "add required" to grab
the RAP ones). I then tried to run it again with no success. So in both my
xml files and my run configurations, I tried to configure for RAP and I'm
still stuck with this same error, each and every time, despite having all
of my required bundles included in every place I can imagine.
Gunnar Wagenknecht wrote:
> Hi Adam,
>> !STACK 1
>> (see config.ini).
> How did you configure your target environment? I run into the same
> problem in the past. I think there is an issue in PDE when Equinox
> bundles are available multiple times in your target platform. At least
> for me this was the case. Thus, I had to create a target platform
> definition manually. However, every time I start Eclipse I have to
> reload the target platform because PDE does not remember it correctly.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=251092
> -Gunnar
Re: Missing required Bundle, wrong version number? [message #109758 is a reply to message #109700] |
Fri, 17 October 2008 13:52   |
Adam,
If you start the app locally in Eclipse, simply type "ss" in your
console window to display all bundles.
Stefan.
Adam schrieb:
> Hi Ralf,
> Thanks for your help...sorry I'm not very familiar with this bundle
> versioning stuff, so I'm not sure how to get the "ss list" for you. I
> went to this page:
> http://wiki.eclipse.org/Where_Is_My_Bundle
> but the instructions are for Windows, and nothing for Unix, so I didn't
> get very far in trying to use that documentation.
> Ralf Sternberg wrote:
>> Adam wrote:
>>> There are no version constraints in my MANIFEST file, and never
>>> were...this just makes no sense!
>> Maybe "0.0.0" stands for "any version"? I think so because I've seen
>> similar error messages when I missed a required bundle that had no
>> explicit version required in the manifest of the referring bundle.
>> Adam, from your stack trace it seems that your org.eclipse.core.runtime
>> bundle is not running:
>> !STACK 1
>> (see config.ini).
>> Can you also post your ss output?
>> Ralf
Re: Missing required Bundle, wrong version number? [message #109788 is a reply to message #109758] |
Sat, 18 October 2008 16:59   |
I can't start the app, that's why I have this problem, so how could I get
the ss list? I'm confused...
Stefan Roeck wrote:
> Adam,
> Regards,
> Stefan.
> Adam schrieb:
>> Hi Ralf,
>> went to this page:
>>> !STACK 1
>>> (see config.ini).
>>> Ralf
Re: Missing required Bundle, wrong version number? [message #109793 is a reply to message #109788] |
Sat, 18 October 2008 18:43   |
Hi Adam,
starting the launch configuration with the "-console" command offers you
a the OSGi console in our "Console" view. This only means that OSGi is
running.
Should look like this:
OSGi>
If this is available, just type "ss" (for short status) and hit return.
This will result in a list with all your bundles including their status.
This information would be good to see in order to track down the problem.
Greets
Benny
> get the ss list? I'm confused...
> Stefan Roeck wrote:
>> Adam,
>> Regards,
>> Stefan.
>> Adam schrieb:
>>> Hi Ralf,
>>> went to this page:
>>> didn't get very far in trying to use that documentation.
>>>> !STACK 1
>>>> (see config.ini).
>>>> Ralf
Re: Missing required Bundle, wrong version number? [message #110337 is a reply to message #110100] |
Thu, 23 October 2008 04:46  |
Originally posted by: rsternberg.innoopract.com
Adam wrote:
> I was reading other threads in this NewsGroup about their RAP problems
> and I was wondering, could my Required Bundle problem be due to the fact
> that I made a copy of my RCP application? Are there files that are
> auto-generated by Eclipse when you create a new RAP application that
> aren't created for RCP applications? I checked New>Project... and didn't
> find a distinction...
No, there's no magic involved. Of course, if you create a RAP
application from a template, the RAP template differs slightly from the
RCP one (as it has to implement the IEntryPoint interface).
Ralf
Current Time: Fri Sep 19 04:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.05536 seconds
