Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR, 4.4.0.2] missing information in test suite editor
[AGR, 4.4.0.2] missing information in test suite editor [message #109628] Tue, 21 August 2007 04:46 Go to next message
I created an AGR test suite with TPTP 4.4.0.1.
When I open the test suite file (same project, same workspace) in TPTP
4.4.0.2, the Behavior page is not displayed and the Test Cases page
shows only the list of test cases. Macro, Object Mine and General
Information boxes are missing.
After opening a new workspace and importing the test project, test suite
editor shows up correctly.
Any idea what goes wrong?
Matthias
Environment:
- TPTP 4.4.0.2 AllinOne + correspondent AGR
- Windows XP SP2
- JRE 1.5 Update 11
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109664 is a reply to message #109628] Tue, 21 August 2007 06:38 Go to previous messageGo to next message
Hi Matthias,
No, we have not seen this behavior. Can you attach your <Eclipse
installation directory/.metadata/.log file?
Paul
"Matthias Wiskow" <matthias.wiskow@windriver.com> wrote in message
news:fae8qj$pnd$1@build.eclipse.org...
> 4.4.0.2, the Behavior page is not displayed and the Test Cases page shows
> only the list of test cases. Macro, Object Mine and General Information
> boxes are missing.
> Matthias
> Environment:
> - Windows XP SP2
> - JRE 1.5 Update 11
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109735 is a reply to message #109628] Tue, 21 August 2007 09:27 Go to previous messageGo to next message
I would guess that you have not installed the AGR into your 4.4.0.2
install. In the absence of the AGR features, your AGR test will be
opened using the generic test suite editor, which is what you are
describing.
If you think you have installed the AGR, double check your install to
make sure the plug-ins and features are in the correct locations. If
you are still stuck, post back and we'll walk you through the OSGI
console to figure out why the AGR plug-ins are not starting.
--Joe
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109748 is a reply to message #109735] Tue, 21 August 2007 10:37 Go to previous messageGo to next message
Paul and Joe,
thanks for your ideas.
I opened the same test suite with TPTP 4.4.0.1 again and saw the same
effect :-/
I cannot fully reproduce what I did during transition to TPTP 4.4.0.2,
but I suspect that I somehow broke workspace or project settings.
Since I can continue working with the imported project in a new
workspace without problems, I suggest to not follow up with this issue
now. I will watch it during next transition.
Is that OK for you?
Matthias
> describing.
> --Joe
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109831 is a reply to message #109748] Thu, 23 August 2007 06:23 Go to previous message
Hi Mattias,
If you can consistently reproduce this issue and you can confirm the AGR
plug-ins are installed correctly, please open a defect against the TPTP
Testing produce and Test.UI.AGRGUIUI component.
Paul
news:faetbt$pq9$1@build.eclipse.org...
> Paul and Joe,
> effect :-/
> I cannot fully reproduce what I did during transition to TPTP 4.4.0.2, but
> Since I can continue working with the imported project in a new workspace
> without problems, I suggest to not follow up with this issue now. I will
> Is that OK for you?
> Matthias
>> describing.
>> make sure the plug-ins and features are in the correct locations. If you
>> are still stuck, post back and we'll walk you through the OSGI console to
>> Thanks,
>> --Joe
Previous Topic:RAC issue on Linux
Next Topic:maximizing problem with dual monitor setup
Current Time: Wed Jul 23 20:22:38 EDT 2025
Powered by FUDForum. Page generated in 1.08127 seconds
