Replacing a bundle from an installed feature [message #109204] |
Tue, 06 May 2008 17:18  |
We have a feature that provides a replacement for org.eclipse.jdt.core.
For doing so we use a version number that adds 1000 to the minor version
of the original jdt.core and count our own version from there.
This approach worked in 3.0 through 3.3.
However, in 3.4M7, installing our features fails with the following message:
Can't find a solution where both: Match[requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/[3.1024.0.OTD T,3.1024.0.OTDT]] and Match[requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/[3.4.0.v_858, 3.4.0.v_858]] would be satisfied.
Unsatisfied dependency: [org.eclipse.sdk.ide 3.4.0.I20080502-0100] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.sdk.feature.group/[3.4 .0.v20080430a-7M7S-BIAlsaTyJM3wfC1lyDjSJz07kSz0bllKuz-Nm_i7, 3.4.0.v20080430a-7M7S-BIAlsaTyJM3wfC1lyDjSJz07kSz0bllKuz-Nm_ i7]
Unsatisfied dependency: [org.eclipse.sdk.feature.group 3.4.0.v20080430a-7M7S-BIAlsaTyJM3wfC1lyDjSJz07kSz0bllKuz-Nm_ i7] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.pde.feature.group/[3.4 .0.v20080430a-7U7U-E_HlNXnS9jCEl2YL3322,3.4.0.v20080430a-7U7 U-E_HlNXnS9jCEl2YL3322]
Unsatisfied dependency: [org.eclipse.sdk.feature.group 3.4.0.v20080430a-7M7S-BIAlsaTyJM3wfC1lyDjSJz07kSz0bllKuz-Nm_ i7] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.feature.group/[3.4 .0.v20080430-0100-7o7tEAXEFpPqmwXZ67BUqkd,3.4.0.v20080430-01 00-7o7tEAXEFpPqmwXZ67BUqkd]
Unsatisfied dependency: [org.eclipse.pde.feature.group 3.4.0.v20080430a-7U7U-E_HlNXnS9jCEl2YL3322] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.feature.group/[3.0 .0,4.0.0)
Unsatisfied dependency: [org.eclipse.jdt.feature.group 3.4.0.v20080430-0100-7o7tEAXEFpPqmwXZ67BUqkd] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/[3.4.0.v_858, 3.4.0.v_858]
In this situation org.eclipse.jdt.core_3.1024.0.OTDT is the
updated version that is (supposedly) fully compatible with 3.4.0.v_858.
The above is when using p2 for installation. Using the classic update manager,
the feature is partially installed (thus not usable), i.e., the files are put
into the features and plugins directories but "About Eclipse SDK Plug-ins"
does not show the replacement nor plugins depending on it.
What is the proper way in Eclipse 3.4 to replace a single bundle that is
referenced by an installed feature by a newer version??
thanks
Stephan Herrmann
Re: Replacing a bundle from an installed feature [message #109670 is a reply to message #109204] |
Tue, 13 May 2008 22:43  |
This issue is being tracked in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=222945
"Stephan Herrmann" <stephan@cs.tu-berlin.de> wrote in message
news:fvqhs6$i2t$1@build.eclipse.org...
> message:
> would be satisfied.
> would be satisfied.
> would be satisfied.
> would be satisfied.
> requiredCapability:
> requiredCapability:
> requiredCapability:
> manager,
> put
> thanks
> Stephan Herrmann
FUDForum. Page generated in 0.26032 seconds
