Problem with plugin-based products [message #1096404] |
Wed, 28 August 2013 06:48  |
Can someone make a sense out of this error?
Project refresh on org.eclipse.emf.cdo.server.product.tcp_h2-feature failed: No component named
org.eclipse.emf.cdo.server.product.tcp_h2-feature is known to Buckminster
org.eclipse.buckminster.core.metadata.MissingComponentException: No component named
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:179)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:185)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.refreshProject(MetadataSynchronizer.java:295)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$MetadataRefreshJob.run(MetadataSynchronizer.java:126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
The error message "No component named org.eclipse.emf.cdo.server.product.tcp_h2-feature is known to Buckminster" is
strange because that is indeed not a component ID but rather a project name (not identical). Is that a bug in Buckminster?
Cheers
/Eike
http://www.esc-net.de
Re: Problem with plugin-based products [message #1100728 is a reply to message #1100711] |
Tue, 03 September 2013 10:04   |
On 09/03/2013 03:32 PM, Eike Stepper wrote:
> Am 03.09.2013 14:25, schrieb Lorenzo Bettini:
>> Hi
>> do you get this problem in the workbench or headlessly?
> Hmm, can't remember now that a week has passed ;-(
>> In the workbench I usually get these problems when I refactor (rename) a
>> project...
> The same problem? With "-feature" appended to a *product name* ?
No, in my case such problems happen if I rename a project or if I move
the project to a different location (with "Refactor"). When this
happens, in the workbench, I have to delete the project from the
workspace, restart Eclipse, and the reimport the project...
HOME: http://www.lorenzobettini.it
XTEXT BOOK:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.27778 seconds
