| Exclude files from CVS synchronize [message #109605] |
Wed, 07 July 2004 03:43  |
Originally posted by: jwitte.alpha-lab.net
I know, this might not be the right place to post this, but I think
there are some people here, having the same problem:
I use CDT/Eclipse for an automake/autoconf project and as such, there
are a lot of filesd genereated, which should not be synchronized to CVS.
Is there a way to exclude all files from the synchronize view, which were
not explicitly added before.
Also: is there a way to get rid of the dialog, which appears, when
commiting ("There are 100000 ressources not under CVS control - do You
want to add them?") -- saying "Yes" here might be dangerous ;)
Jochen
| Re: Exclude files from CVS synchronize [message #109618 is a reply to message #109605] |
Wed, 07 July 2004 04:49   |
> Regards
> Jochen
you can do this in windows/preferences/team/ignored resources
add what you want to exclude -> *.class, ....
| Re: Exclude files from CVS synchronize [message #109795 is a reply to message #109618] |
Thu, 08 July 2004 01:44  |
Am Wed, 07 Jul 2004 08:49:54 +0000 schrieb psor:
>> Regards
>> Jochen
OK, works -- but these are eclipse-wide preferences, which is not so nice,
since in this project, I have lots of generated Makefiles, which
should not be added to CVS, whereas I have Makefiles in another project
which should of course be added to CVS (just as an example). Excluding
them by hand is not an option.
It would be nice, if I would be able to set this on a per project basis,
rather than eclipse-wide.
FUDForum. Page generated in 0.04557 seconds
