Home » Archived » Visual Editor (VE) » Finish button stays disabled in VE Wizard
Finish button stays disabled in VE Wizard [message #109458] Thu, 13 October 2005 11:19 Go to next message
Originally posted by: peterohl.yahoo.com
Has anybody a solution to this?
I have VE installed, I start the New->VisualClass Wizard,
I enter a nice class name, select the style super class -
but this "Finish" button stays disabled. No way to
get it enabled and to create a new class with this wizard.
(I can create VE example classes and they run nicely.)
I'm running on WinXP:
Eclipse Version: 3.1.1 Build id: M20050929-0840
GEF 3.1.1
EMF 1.1.0.1
VE 1.1.0.1
I'm not stupid - but maybe I'm doing something terribly
wrong...
Thanks for any help!
- Peter.
Re: Finish button stays disabled in VE Wizard [message #109552 is a reply to message #109458] Thu, 13 October 2005 19:10 Go to previous messageGo to next message
If this happens there is usually a message at the top of dialog
explaining why.
> GEF 3.1.1
> EMF 1.1.0.1
> VE 1.1.0.1
> I'm not stupid - but maybe I'm doing something terribly wrong...
> - Peter.
Rich Kulp
Re: Finish button stays disabled in VE Wizard [message #109591 is a reply to message #109552] Fri, 14 October 2005 03:35 Go to previous messageGo to next message
Not really.
Nothing there.
Also the "Error Log" view is silent. No log file in my
<workspace>/.metadata
directory. Nothing.
I'm really stuck.
Very strange.
Re: Finish button stays disabled in VE Wizard [message #109601 is a reply to message #109591] Fri, 14 October 2005 05:22 Go to previous messageGo to next message
> Rich Kulp wrote:
> > If this happens there is usually a message at the top of dialog explaining
why.
Exquisitus wrote:
> Not really.
> Nothing there.
> directory. Nothing.
> I'm really stuck.
> Very strange.
I also tried running it with WinAdmin rights (thought it could be a
permission thing) - but that didn't help either.
Any more ideas??
thanks!
- Peter.
Re: Finish button stays disabled in VE Wizard [message #109614 is a reply to message #109601] Fri, 14 October 2005 10:52 Go to previous messageGo to next message
Can you give me a screen capture of where you entirely filled in the
wizard correctly but the finished doesn't enable?
Rich Kulp
Re: Finish button stays disabled in VE Wizard [message #109627 is a reply to message #109614] Fri, 14 October 2005 11:57 Go to previous messageGo to next message
Sure - I first need to figure out where to upload it for you though or how
to attach it with this web interface I'm using here.
BUT: I just figured out it's a thing with my workspace. I've just created
a new empty workspace, added a Plug-in project and added a VisualClass to
a package in there. That worked.
Not sure what's different with my other workspace, except it's under CVS
control, it contains 15+ projects and Idontknowhowmany java files - but
that shouldn't hurt, should it?
So, for me that's a workaround to get me going. I can create VE classes
and start working. If you are still interested in hunting it down (as it
still doesn't look like an user error to me, so far), I'd be willing to
try a couple of things.
Thanks for your responses.
- Peter.
Re: Finish button stays disabled in VE Wizard [message #109640 is a reply to message #109627] Fri, 14 October 2005 13:57 Go to previous message
My email id is the id this note except remove the Spam.
Rich Kulp
Re: Finish button stays disabled in VE Wizard [message #611196 is a reply to message #109458] Thu, 13 October 2005 19:10 Go to previous message
explaining why.
> GEF 3.1.1
> EMF 1.1.0.1
> VE 1.1.0.1
> - Peter.
Rich Kulp
Re: Finish button stays disabled in VE Wizard [message #611199 is a reply to message #109552] Fri, 14 October 2005 03:35 Go to previous message
Not really.
Nothing there.
directory. Nothing.
I'm really stuck.
Very strange.
Re: Finish button stays disabled in VE Wizard [message #611200 is a reply to message #109591] Fri, 14 October 2005 05:22 Go to previous message
why.
Exquisitus wrote:
> Not really.
> Nothing there.
> directory. Nothing.
> I'm really stuck.
> Very strange.
Any more ideas??
thanks!
- Peter.
Re: Finish button stays disabled in VE Wizard [message #611201 is a reply to message #109601] Fri, 14 October 2005 10:52 Go to previous message
Rich Kulp
Re: Finish button stays disabled in VE Wizard [message #611202 is a reply to message #109614] Fri, 14 October 2005 11:57 Go to previous message
- Peter.
Re: Finish button stays disabled in VE Wizard [message #611203 is a reply to message #109627] Fri, 14 October 2005 13:57 Go to previous message
Rich Kulp
Previous Topic:VE problem with AMD 64 bits
Next Topic:Adding a SelectionListener to a TabFolder confuses VE parser
Current Time: Fri Jul 25 11:40:39 EDT 2025
Powered by FUDForum. Page generated in 0.19835 seconds
