Home » Modeling » M2T (model-to-text transformation) » [Xpand] Stereotype problem(Problem when applying a Stereotype )
[Xpand] Stereotype problem [message #1095601] Tue, 27 August 2013 05:19 Go to next message
Hello Everyone,
I have a problem when using xpand with a model that has a stereotype on some classes (the stereotype is defined and applied on classes).
The problem is that when a class has the stereotype Xpand does only recognize that its actually a uml::class but only the stereotype. This seems to be fine but in our situation the stereotype is only a marker that has no attributes/tags. So basically every class that has the stereotyp cannot be used anymore.
here is a small example of what i try to do:
«FOREACH ownedElement AS c ITERATOR iter SEPARATOR ','»
«IF uml::AssociationClass.isInstance(c)»
 «EXPAND AssociationClassRoot(packageName+"666"+this.name) FOR c»
«ELSEIF uml::Class.isInstance(c)»
 «EXPAND ClassRoot(packageName+"111"+this.name) FOR c»
«ELSEIF uml::Package.isInstance(c)»
 «EXPAND ClassRoot(packageName+"1"+this.name) FOR c»
«ENDIF»
«ENDFOREACH»
The problem here is that every class with the stereotype cannot be processed by
whereby ClassRoot is defined for packages classes etc such as
«DEFINE ClassRoot(String packageName) FOR uml::Class»
if I add a rule like
«ELSEIF MoVEExecutableProfile::InternalElement.isInstance(c)»
«EXPAND ClassRoot(this.name) FOR c»
with a correspondig DEFINE statement, I do not get any exceptions but of course since InternalElement is only a marker I cannot do anything with the element..
for example this.name does not work or just throws exceptions..
I hope I could express my problem?
I tried several version to solve the type problem for example with typecasting like
 «EXPAND ClassRoot(packageName+"111"+this.name) FOR (uml:class) c
None of the "solutions" helped..
Do you have an idea of what I could do?
Thanks for any help!
Re: [Xpand] Stereotype problem [message #1095859 is a reply to message #1095601] Tue, 27 August 2013 12:25 Go to previous messageGo to next message
can you share a little example project?
Re: [Xpand] Stereotype problem [message #1095883 is a reply to message #1095859] Tue, 27 August 2013 13:15 Go to previous messageGo to next message
P.S: depending on how you definded the property you may find the following in the log
ERROR StereotypeType - Couldn't find type for Whatever
Re: [Xpand] Stereotype problem [message #1095897 is a reply to message #1095883] Tue, 27 August 2013 13:32 Go to previous message
so depeding on your version you may be affected by https://bugs.eclipse.org/bugs/show_bug.cgi?id=333605
Previous Topic:[acceleo] Run Acceleo M2T JUnit Test from tycho
Next Topic:[Acceleo] Target folder outside workspace in absolute path
Current Time: Mon Sep 15 13:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.04538 seconds
