Home » Modeling » GMF (Graphical Modeling Framework) » why transform doesn't do any things!
why transform doesn't do any things! [message #1079576] Sun, 04 August 2013 16:31 Go to next message
I want to generate .gmfgen by GMF. in GMF dashboard after generating of .gmfmap model click on transform but without showing error or warning, don't happen thing! I'm used even from right clicking on .gmfmap model and selecting of "create generator model" , but this mean is not useful and i cant create .gmfgen model!
do you can help me?!
[Updated on: Sun, 04 August 2013 16:41] by Moderator
Re: why transform doesn't do any things! [message #1088907 is a reply to message #1079576] Sat, 17 August 2013 18:02 Go to previous messageGo to next message
this problem contains errors but must see it's errors in error log!
for adding error log to workspace, select windows>show view> error log!
after adding of error log, i get "Unhandled event loop exception" error! and for solving this error, i removed eclipse and installed it again!
note: i get error about not finding of workbench when i run my prj! for solving this, i moved all prj to folder with name of workspace in folder of my eclipse and switched workspace to this new workspace.(in other word created local workspace)
I reported these and hope if would be useful:)
[Updated on: Sat, 17 August 2013 18:07] by Moderator
Re: why transform doesn't do any things! [message #1095008 is a reply to message #1088907] Mon, 26 August 2013 10:04 Go to previous messageGo to next message
to find out what the problem is it helps to validate the gmfmap, gmfgraph, and tooling models. Right-click the root of these models and select validate. Is there any error displayed?
Ralph
Re: why transform doesn't do any things! [message #1096497 is a reply to message #1095008] Wed, 28 August 2013 09:22 Go to previous messageGo to next message
Ralph Gerbig wrote on Mon, 26 August 2013 10:04
Ralph
Thanks Ralph but now i get "application error" when run my GMF as eclipse application. this error is pasted in below. do you know about it?
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: why transform doesn't do any things! [message #1097119 is a reply to message #1096497] Thu, 29 August 2013 04:58 Go to previous messageGo to next message
are you running it as an Eclipse Product?!
Ralph
Re: why transform doesn't do any things! [message #1098244 is a reply to message #1097119] Fri, 30 August 2013 16:53 Go to previous messageGo to next message
Ralph Gerbig wrote on Thu, 29 August 2013 04:58
Ralph
No, i run it as eclipse application. i go to run configuration and i add .diagram, .editor and required plug-ins in 'plug-ins>plug-ins selected below only' tab and then click on run! but for some my project i get that error!
Re: why transform doesn't do any things! [message #1106546 is a reply to message #1098244] Wed, 11 September 2013 04:36 Go to previous message
there is somewhere a checkbox which you can check to validate the plugin selection on startup. Maybe you are just missing a plugin dependency that is not automatically added.
Ralph
[Updated on: Wed, 11 September 2013 04:36] by Moderator
Previous Topic:Adding label to ScalableImageFigure
Next Topic:Drag and drop from Palette into a compartment issue
Current Time: Wed Jul 23 07:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.26225 seconds
